Solder in a stripped zerk???
/ Solder in a stripped zerk??? #1
Sebculb
Gold Member
SW Costa Rica
'97 Deere 310D Backhoe
Hola,
So here's the latest big idea, if I've got a stripped hole for a zerk on the end of one of the pins that holds my rear bucket on, is there any reason I can't solder it in there? I stick weld okay but have no soldering or brazing experience, except for that time an electronics thing didn't really work right.
Anyone have any experience with this? What would I do, heat it up with a torch and slather solder on the joint? Don't want to worry about taps and dies, expensive and hard to find around here. Same with helocoils and "special" zerks.
Thanks!
/ Solder in a stripped zerk??? #2
you couldn't get the pin hot enough for solder flow and it doesn't have much tensile strength, brazing might hold.
/ Solder in a stripped zerk??? #3
Hola,
Thanks!
I doubt that solder will work for your required application.
When you push grease through the soldered in zerk, the grease pressure will likely back the zerk out.
Can you take the tractor to some local shop? I do think that brazing could work.
3rd world countries tend to have have many talented people who can fix something with nothing.
Thanks, Lou and Fried!
Can brazing be done with a regular propane torch? I prefer to learn how whenever possible.
Also considering an idea I saw somewhere else, weld a nut that the zerk fits into over the stripped hole. That's actually how problems are usually solved in this world where a tap and dies are scarce and considered specialty tools.
/ Solder in a stripped zerk??? #6
Zerks come in different thread sizes. Most would simply retap the hole one size up and put a new zerk in.
/ Solder in a stripped zerk??? #8
Find a zerk (SAE or Metric) that is slightly larger. Use a file or hacksaw blade to cut a longitudinal groove in the threads and you have a self threading zerk!
/ Solder in a stripped zerk??? #9
Yes you could braze it successfully but the heat would probably destroy the spring in the zerk. Drill and retap like others have suggested.
Air biscuit, I'm liking it! But Zerks around here come in three sizes, small big and huge. Wouldn't really fit.
RNeuman, Flingwing, and Big Barn, yes, you're absolutely right. But drilling and Tapping involves finding someone that has the right tap and disassembling and paying money and blah blah. I was hoping to just put a chewing gum on it and keep moving.
/ Solder in a stripped zerk??? #11
I’ve never disassembled anything when retapping a broken zerk. This is a tractor FEL etc- not some aerospace thing with tolerances down to the 10,000th. A few metal chips will blow through with a few pumps of grease. U can stick a magnet to your tap if u r really worried.
/ Solder in a stripped zerk??? #12
Wouldn't think you could ever get and keep (grease is going to flow when you heat it up) the metal clean enough to braze without disassembly. Re-tap it, use a helicoil if going the next zerk size up isn't an option.
/ Solder in a stripped zerk??? #13
I would just pein it a few times with a hammer or even hit the hole with a center punch a few times. Then install a new Zerk (or even the old one. A grease gun ought to have enough grunt to fill the pin slot without blowing the Zerk out or all the charge grease. I have several in a kit which look like they were self tapping with a graduated thread diameter. Look around for old machinery to borrow one from.
/ Solder in a stripped zerk??? #14
Good luck with your chewing gum since you tend to ignore sound advice from people who are trying to help you. :rolleyes:
/ Solder in a stripped zerk??? #15
Now...THAT is a god idea!
Simple fix!
/ Solder in a stripped zerk??? #16
If the internal thread is tapered as a lot of pipe threads are, would be a matter of finding the standard tap and just threading a little deeper to renew the threads.
A thread used quite commonly for a grease zerk, here in the U.S. at least, is 1/8"-27NPT. The 1/8" is a pipe size and a bit misleading as the thread diameter is closer to 5/16" give or take.
Thanks everyone for all the advice. since the taps are hard to come by here think I'm going to try to fix it the way they do most thread problems around here. I'll try to weld a nut on the end of the pin over the stripped hole. That's hardly Mickey mouse and I can do it with what's here. Probably have to go to the capital to find a tap and die set. I'll post up if it works or not
/ Solder in a stripped zerk??? #18
I would find a nipple with the same thread and bury it as deep as possible with out stripping it, then screw a collar and new zerk.
Maybe JB weld might hold it too. If all else fails and I didnt have a tap set, then do as you said just weld (tack it) and be finish.
/ Solder in a stripped zerk??? #19
I have a stripped out zerk in a thin walled mower wheel hub where I can't get a tap or drill because of the rim curvature. I tryed every size zerk I could find for a tight fit and couldn't get anything that would survive the force of coupling/uncoupling the grease gun. But I did discover that if I stuck the correct zerk into the grease gun hose then jammed the threaded end of the zerk into the stripped hole and pumped I could grease the joint. Leaked a little around the zerk but not much. My only problem now is finding a zerk in my messy box.
gg
/ Solder in a stripped zerk??? #20
I've done this, and I've also switched from Metric to Standard thread, or the other way around, and re tapped the threads with good results.
213098 (A64276)
213098 (A64276)
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
AGT ATK-B1000 2 Post Car Lift (A64127)
AGT ATK-B1000 2...
1992 Rammax 7430 Trench Packer and Extra Set of Drums (A62613)
1992 Rammax 7430...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
