Forum for air cooled diesel engines and clones
   / Forum for air cooled diesel engines and clones #342
A variation on the technique as 90cummins describes in post #321!
I wouldn稚 go beating on the generator field unit.
Pushing it off is the proper procedure.
90cummins
   / Forum for air cooled diesel engines and clones #344
   / Forum for air cooled diesel engines and clones #345
I got it all apart.
The armature (rotor) came out quite easily, I couldn't find a rod that would fit right, so I whacked it with a rubber mallet a few times and it popped off without much of a fight, soaking in pb blaster for a few days helped too I'm sure.
I then pulled the valve cover off, cylinder head, everything looks clean, no visible damage of any sort, very little carbon buildup, no scoring on cylinder walls, no play in anything.
I didn't open up the crankcase, I'm not sure I should since I don't see anything wrong on the top end, but I'd like to hear some opinions from the experts.
Here are a few pics of what everything looks like.
seems the rest of my pictures are having a hard time uploading, I'll try again a in a bit
xp
If I had it torn down this far I’d open it up.
Pull the piston & check the rod bearing then there are no questions.
Carbon buildup in the ring lands can cause issues better to check now then to go back later.
90cummins
   / Forum for air cooled diesel engines and clones #347
Hi All -
Has anyone got torque specs for these engines? Connecting rod, crankcase cover, head bolts, etc?
Thank you!
   / Forum for air cooled diesel engines and clones #348
Looks like it will be a while before my gasket kit gets here, so I might as well tear the whole thing down and check it all over. I'll post more pictures once I get down into it.
xp
This should help.
90cummins
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
Peterbilt 377 Semi-Truck (A55315)
Peterbilt 377...
2016 PETERBILT 579 TANDEM AXLE MID ROOF SLEEPER TRUCK (A54607)
2016 PETERBILT 579...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
Carnival Ticket Booth (A51691)
Carnival Ticket...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A55852)
2006 Ford F-550...
