Grapple Grapple without additional Hydraulics
/ Grapple without additional Hydraulics #1
majorwager
western new york
kubota mx 5100 IH 484 ford 1620 lull 844b
Was unaware of such an animal. Perhaps my life is sheltered, but Westendorf offers a tool called the brush crusher. A grapple that operates without the necessity for a third function. Those that are aware will simply yawn, with that "where have you been smirk", others may go take a look. No link provided, where is the fun in that?
/ Grapple without additional Hydraulics #2
Yup, they exist. Put me in the “Where have you been?” category.
/ Grapple without additional Hydraulics #3
I saw them at the national farm machinery show. If it wasn't for that I probably wouldn't know they exist.
Aquamoose,
Familiar with that phrase that is all the rage now? See something, say something. Anyway it appears a novel concept as some posts indicate members are hesitant to purchase a grapple due to the wide variety of costs associated with adding third function capability. Will try to get out more in the future, just passed up a large farm show last week in Syracuse, guess that was a mistake.
/ Grapple without additional Hydraulics #5
Really like that idea! If they will work with a SKQA I would be a buyer probably!
Got to be priced better than a $1500 grapple and $800 3rd function.
/ Grapple without additional Hydraulics #6
Not from what I saw... listed at over $4000...
/ Grapple without additional Hydraulics #7
Aquamoose,
I’m certainly aware of the phrase but if you ask me how I know about it, I googled up “Grapple” and all sorts of information was presented. I was in the market for a grapple when I learned about that unique grapple but settled on an ANBO grapple. If I could do it, so can you. Try it sometime on your computer in the search bar of your favorite search engine. It’s an amazing feature.
Aquamoose,
Your extensive knowledge of information technology is most enlightening. Have transfered your detailed instructions to a posted note directly above the center monitor where it will provide eternal reference. Unequivocally the Stephen Hawkins of tractor forums.
/ Grapple without additional Hydraulics #10
The fear with these is that the two "grapples" are not rigidly linked together, so they can twist when picking up uneven loads. A guy on the GTT forum tried one and the center "timing rod" between then two sides broke- that means the loader arms where flexing.
Something I wrote in that thread, there are many good points discussed too.
The issue of "rigidity" as we are discussing comes from the fact that with this implement attached there is nothing tying the two arms of the loader together anymore except for the round tube between the arms. With the bucket, forks, or traditional grapple attached the implement itself helps to tie everything together. Will this be enough? Only time will tell.
/ Grapple without additional Hydraulics #11
The brush crusher for a smaller tractor like your kioti, will cost much less than that. I paid about 1300 for a smaller set. They can be a pain to hook up, but they handle brush and logs very well. IMG_0906.JPG here is a picture of my set on a 35 hp tractor moving a 20 ft log. The amount of brush you can pick up is impressive and allow for fast cleanup. W Jones
/ Grapple without additional Hydraulics #13
Thanks for pointing these out. I was unaware of them as well.
Perhaps it would be appropriate to combine this thread with the example noted by Xfaxman from 2007.
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
2016 16ft. C and S Lawhon 2.5 Ton Pipe Top T/A Utility Trailer (A60352)
2016 16ft. C and S...
High Accuracy Meter Fuel Pump (A61166)
High Accuracy...
2018 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A59906)
2018 FREIGHTLINER...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
