John deere 970 clutch question
/ John deere 970 clutch question #1
dooll
st-nazaire
john deere
At quote 11, it's written to leave a .6 "gap between the bolt head and the clutch cover, I want to know why when I removed the worn clutch there was no space to this place.
/ John deere 970 clutch question #2
You have two clutches one on top of the other. One is for the pto and the other for the main drive.
As the disk wears, the clearance you mention is gradually disappearing as the disk becomes thinner. The gap might also disappear even with a new disk when you depress the clutch(s)
I have not read the WSM but it could be that this clearance is a design feature within the dual clutch so that it starts slipping before the flywheel or place where the second clutch engages, from being damaged from rivets etc.
Dave M7040
/ John deere 970 clutch question #3
I assume you just made a typo but the gap is .060, not .6
/ John deere 970 clutch question #4
The dualstageclutch has 2 settings. That 0.060' is the setting for the second stage (to disengage the pto)
If not enough the pedal will be very hard ( like disengaging both at the same time)
If to much your pto can not disengage(will not stop)
perfect, thanks for those answers
Spirit Electric Bicycle (A64127)
Spirit Electric...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
2022 Deere 17G (A64126)
2022 Deere 17G...
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
Big Foot Sign (A64127)
