Does Anyone Braze Anymore ??
/ Does Anyone Braze Anymore ?? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I had to make a split bushing today so I could use a Cat 1 top link on a Cat 2 implement. I brazed the short bushing pieces to the washers so the parts would be easier to find in the tool box and easier the assemble. Brazing was fast and easy. Maybe 5 minutes. I never hear anyone mention brazing now-a-days. Is it just to mundane to talk about or is it a process of the past? I still braze lots of stuff. If I tried to stick weld this it would be a mess.
gg
/ Does Anyone Braze Anymore ?? #2
I still braze occasionally, my multi process will do DC TIG but have no need so far, may someday but dono, I'm gettin old!
/ Does Anyone Braze Anymore ?? #3
I have two stick welders and a mig but I still braze. The mig is a HF cheapy and only has a couple settings and usually blows through light metal too easily. The majority of my brazing is exhaust system piping and I find it easier and faster to braze. I usually use wire coat hangars and they do a great job. I've thought of buying a TIG but not worth the cost for the amount I'd use it.
/ Does Anyone Braze Anymore ?? #4
I have brazed many items and find it very handy for more delicate work. I have used it to clad bolts when used as an axle so they do not corrode when subjected to salt spray or calcium spray. There are many different alloys available and a little research will enlighten many with the tinsel strengths of the materials available. It is another tool in my kit-bag for repairs etc. Bob
/ Does Anyone Braze Anymore ?? #5
George,
Wire coat hangers for brazing? What am I missing here?
/ Does Anyone Braze Anymore ?? #6
I have used TIG brazing for cast using Alum-bronze rod. I liked it, very controllable.
I have not oxy/acetylene brazed anything.
I enjoy oxy/acetylene welding, but only do it in class for the student demonstrations.
Your braze looks great Gordon :D I would have TIG welded it only because it's easier for me.
/ Does Anyone Braze Anymore ?? #7
Unless he has a stash of coat hangers made of brass wire, that would be O/A fusion welding with mild steel. Brazing doesn't require melting the base metals to achieve joining. It's more like soldering in that respect.
/ Does Anyone Braze Anymore ?? #8
George,
I don't know what you are missing. I was brazing something many years ago and ran out of brazing rod on a weekend. A welding buddy of mine told me to borrow some coat hangars from the wife to finish the job. I did and they worked great and I've been using them ever since. Try it sometime.
I just get the two sections of exhaust pipe cherry red and the feed the coat hangar. As it melts it flows right where it should. The brass hangars are getting harder to come by but once in a while a buddy of mine runs across a stash and drops them off. Last time I bought actual brazing rod was over ten years ago.
Maybe I should have called it fusion welding with mild steel as Dan said.
/ Does Anyone Braze Anymore ?? #9
I'd be happy to try it, but I only have coat hangars made with steel wire. Never seen brass wire coat hangars. Steel wire is welding, brass is brazing.
/ Does Anyone Braze Anymore ?? #10
To me; using "wire coat hangers", is gas welding.
When I "braze" I use brass rod.
/ Does Anyone Braze Anymore ?? #11
Some coat hangers work ok and I have tried them for welding but. Steel, Brass, SIB, 4130 etc. Just do a nicer job. Some of the old hangers work better than the new stuff. Clean with a scotch-brite 1st though. I like the old 14FC nickel silver coated rods. You can braze overhead with them.
/ Does Anyone Braze Anymore ?? #12
You are correct so I mis-spoke. I use steel hangar wire as the brass ones are harder to find so technically I'm welding using an O/A torch.
/ Does Anyone Braze Anymore ?? #13
My Grandson is taking a Vo Tech Welding class in his Junior year of High School. I was very pleased to learn the other day that they are teaching him all aspects including TIG, Brazing and O/A welding. He's eating it up. Wants to go professional as a career. He's sure got a steady hand!!!! :)
/ Does Anyone Braze Anymore ?? #14
I love to braze and O/A weld!
Both will handle jobs that are much harder otherwise.
Been doing both since the 60's in high school.
Don't know if I have ever used store bought O/A steel rods. ???
Coat hangers rule!
/ Does Anyone Braze Anymore ?? #15
I like that #14 nickle bronze rod too. Sometimes it was called nickle silver but I don't believe there's any silver in it. It works almost exactly like regular brass brazing rod except like you say it has a higher surface tension as it melts. That's useful for doing free-hand work with the torch because a guy can wiggle the puddle into shapes as it melts. There used to be a whole world of non-ferrous rods available for oddball oxy/acetylene welding and brazing - but not so much anymore.
Here's a couple of examples of torch work along with a torch tip I made for doing fine work. The belt buckle's outer ring is regular low fuming brass or bronze rod wound around a piece of water pipe, brazed into a ring, and beaten into an oval over the horn of an anvil. The silver colored metal used for the inner design is that #14 nickel silver you mentioned.
The belt in the picture is 1 1/4" wide, so that buckle is about 1 1/2" tall overall.
enjoy,
rScotty
/ Does Anyone Braze Anymore ?? #16
I have used TIG brazing for cast using Alum-bronze rod. I liked it, very controllable..
Hi Dave, can you tell me which Alum-Bronz rod you are using, I see there are a couple different ones. Do you pre/post heat on the cast? DC NEG? What tungsten? I was in on the big brazing thread over at WW before the crash and I've been carrying on with my experimenting with pre-fluxed and bare bronze with O/A. With WW down I've been lurking and joined tonight. I also ordered some Bernzomatic NS-3 to try, and yesterday I received some EZ Weld Tig Wire for cast, have you tried them?
/ Does Anyone Braze Anymore ?? #17
I used the uncoated A2 version as it was rated for joining. I preheated a little, welded on AC with the balance mostly to negative.
I basically just followed what Jody on weldingtipsandtricks posted in his video on the subject.
/ Does Anyone Braze Anymore ?? #18
OK thanks. I only have a DC machine.
/ Does Anyone Braze Anymore ?? #20
From the use what you got corner-
Saw a How it's made where a Swiss guy was making a very large decorative cow bell and he used a spent brass rifle cartridge for the brass filler!
2016 Ford F-450 Liftmoore 2550 5,000lb. Crane Service Truck (A66736)
2016 Ford F-450...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
2017 John Deere 331G Compact Track Loader Skid Steer (A66734)
2017 John Deere...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A66734)
2025 Kivel Quick...
2023 Tesla Model 3 Sedan (A66738)
2023 Tesla Model 3...
