Name that tool and how do you use it
/ Name that tool and how do you use it #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I am starting the process of going through my inheritance of sorts. It is primarily a large scale wood shop but there are some other tools thrown in. These are the first five I am unsure of enough to ask if anyone knows. I have an idea on all of them but would love a better idea than my best guess.
/ Name that tool and how do you use it #2
It looks like 4 is for fence “hog clips”.
/ Name that tool and how do you use it #5
#3 reminds me of something (possibly a set) of a 'positioning guide'... used to slide two things together prior to bolting/fastening them together.
/ Name that tool and how do you use it #6
They look like the tools you would use to put large flat belts together. Hole punch, awl, spacing tool and clip squeezer.
/ Name that tool and how do you use it #8
I think I saw all of those in the window of a BDSM shop in the bay area....
/ Name that tool and how do you use it #9
C'mon, you guys don't know a grostling iron when you see one?? :confused3:
/ Name that tool and how do you use it #10
LOL, and 5 looks like a back scratcher.
Agree with most remarks.
3 has a square end like to accept a tool also a hole for a rod, ie to add power.
Might have been used as a reamer of sorts.
1 is the puzzler.
Seems to be shaped from a large common nail (see marks at top) but has a screwdriver like flattened bottom end.
However the 'head end' seems to have been reworked for a specific purpose.
/ Name that tool and how do you use it #11
Probably never know about #1 unless you can talk to the person that modified it. Obviously modified for some quite specific task.
Thanks all. What is really embarassing is that the Kerf Setter and the Hog Pliers I have both used a lot in my childhood. My father was against power equipment when I was young so we cut all our wood with buck saws. One man and two man saws. Learned to sharpen and kerf. I knew what I was looking at but it never rang a bell. Same with the pliers. I think you are probably right on the one tool being an alignment tool. The previous owner was a lineman, probably something to line up holes on power poles. The last is maybe home made or a modification. It is nasty nasty sharp. Not sure what you would use it for as it removes flesh (not a back scratcher).
So the one tool with the chunk of metal at the top... there are 4 of them in the tool kit I was given. No clue. It does have a look of maybe an old screw driver with this nob welde on but it makes no sense. Not sure what you would use it for.
/ Name that tool and how do you use it #18
.. 1 .. Seems to be shaped from a large common nail (see marks at top) ...
My first thought, and for just that reason .. Not all from the same era, I'd say ...
3 could be a spud/drift .. with the square or pin hole to twist/pull when bound (used for that anyway) .. 4 is also used by upholsterers for their "hog rings" (wire & excelsior relics) .. I've seen 5 sold as a 'foot scratcher' (cross legs at knees), though I might advise it for raking cockle burs from the dog or cat.
/ Name that tool and how do you use it #19
Home made tent stakes?
