Name that tool and how do you use it
   / Name that tool and how do you use it #11
Probably never know about #1 unless you can talk to the person that modified it. Obviously modified for some quite specific task.
Thanks all. What is really embarassing is that the Kerf Setter and the Hog Pliers I have both used a lot in my childhood. My father was against power equipment when I was young so we cut all our wood with buck saws. One man and two man saws. Learned to sharpen and kerf. I knew what I was looking at but it never rang a bell. Same with the pliers. I think you are probably right on the one tool being an alignment tool. The previous owner was a lineman, probably something to line up holes on power poles. The last is maybe home made or a modification. It is nasty nasty sharp. Not sure what you would use it for as it removes flesh (not a back scratcher).
So the one tool with the chunk of metal at the top... there are 4 of them in the tool kit I was given. No clue. It does have a look of maybe an old screw driver with this nob welde on but it makes no sense. Not sure what you would use it for.
   / Name that tool and how do you use it #18
.. 1 .. Seems to be shaped from a large common nail (see marks at top) ...
My first thought, and for just that reason .. Not all from the same era, I'd say ...
3 could be a spud/drift .. with the square or pin hole to twist/pull when bound (used for that anyway) .. 4 is also used by upholsterers for their "hog rings" (wire & excelsior relics) .. I've seen 5 sold as a 'foot scratcher' (cross legs at knees), though I might advise it for raking cockle burs from the dog or cat.
   / Name that tool and how do you use it #19
Home made tent stakes?
1996 Sunflower 1543-38 Folding Disk (A56438)
1996 Sunflower...
1969 VOLKSWAGEN BUG (A59575)
1969 VOLKSWAGEN...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
