PTO sprayer or 12v
/ PTO sprayer or 12v #22
I really like that sprayer....I have never seen that one or the other side by side sprayer someone posted earlier....I paid a lot of money for mine and thought I had looked at all the higher quality side by side sprayer, but obviously not. What type of pump motor do you have on this sprayer? Gas? Electric? How big is the boom? How many gallons is the tank?
This is the one I linked earlier. 20 boom, 30 boomless nozzles. Works great and the gps makes it easy to mark where I have sprayed to reduce overlap
Brett
/ PTO sprayer or 12v #23
Cool. I like those sprayers. Mine is a F/S UTV Sprayer...I would suggest the OP to look at any of the sprayers posted. They are great and hold a large amount of spray. I have a 20 foot boom and wand with 100 feet of hose that allows me to spray like Tru-Greens when I want to put it on. The little Honda GX engine is a work horse. Kind of a pain loading and unloading. They make some legs for it I need to get. GPS is nice! What crops and chemicals are you spraying where you need that kind of accuracy?
/ PTO sprayer or 12v #24
View attachment 541433View attachment 541434
Pretty slick. Why do you have the boom so high? Spraying tall weeds? Does yours not have pallet fork sleeves? If not could you weld some on the bottom to make it easier to load?
I’m not spraying anything that’s so sensitive that I don’t want overspray. I want to ensure I don’t miss any places and want to reduce over application and wasting material. When running my batwing, I put it on the Deere and it has helped me reduce overlap and increase productivity
Brett
/ PTO sprayer or 12v #25
Brett
That is actually lower than it appears....and I get some squat when she's loaded. I used to spray some very expensive chemicals, but now that I have switched to roundup ready alfalfa nothing I spray is terrible expensive....except thomstone insecticide. I had a foam marker setup, but it was a pain and just another thing I had to deal with. Spraying is my least favorite chore of anything I do. I just don't like it...but the results are so "killler" I keep doing it.
I spray corn, soybeans, and roundup ready alfalfa...sometimes my lawn but will mostly use that turf gun for that and now I have my BX tractor and the BX sprayer device Ryan makes from BxPanded I will use the lil bota and fimco. I also do termite applications with it, but again that involves a wand and pulling hose. Most of my perimeter pesticides with the exception of termite application are performed with a stilhl backpack sprayer or the handy B&G hand can.
/ PTO sprayer or 12v #26
We have a 20 gallon hand-held electric sprayer. We haul it in a small trailer behind an ATV or the equivalent with a deep-cycle 12v battery in the trailer with the sprayer tank. It works well but it takes a long time to cover any significant area. Last year we bought a 55 gallon PTO sprayer from Everything Attachments. 12' boom. We operate this sprayer with the PTO speed not much above idle. It works very well and we now use it for every application possible. We had some initial issues with broken nozzles, etc., but the EA folks took care of all problems in an expedited manner.
/ PTO sprayer or 12v #27
60 Gallons, 18 foot boom and 12 volt Remco pump.
Thanks going to ck these out also. Looking for quality but in a 40 to 60 gallon range.
/ PTO sprayer or 12v #30
Oh, heck any suitable container that U can haul, open or closed, and a 12 volt Surflo pump such as used in RV's and you have a DIY sprayer!
I once used the wand from a discarded pump sprayer as my hand held tool.
You could get creative and use some copper piping with a 'T' between two capped equal lengths of pipe that had tiny holes drilled every 2" or so for a drive by spraying job.
You'd then adjust the driving speed to control the application flow.
Sureflow has different flow rate pumps as well as a variety of voltages.
After usage you would want to rinse out the pump thoroughly otherwise corrosion will set in.
Another thought: Have you considered a landscape rake? Cheaper to use, little to no maintenance, environmentally friendly. I have about 300 of stone drive and that is what I do. When the weeds get intolerable I just dress up the road with a rake. Keeps it crowned and pot hole free too. Probably takes a bit longer to do than spraying. But, then you have to clean the sprayer. So may be not. Depending on how picky you are, I only do it a couple of times per year.
roger that. I have a landscape rake and a land plane but most of my weed problems are around edge of drive and large graveled area around shop. Thanks.
/ PTO sprayer or 12v #32
Another thought.
With a product such as roundup dragging a soaked width of outdoor carpeting that is wetted with roundup will accomplish what U want to do.
Creatively speaking a dragged carpet section could use a similarly drilled pipe section to allow constant dripping and wetting.
This way you would have no overspray!
Had a buddy that simply soaked a cotton glove in roundup and hand wiped all the unwanted weeds in his garden thus saving all the good plants/flowers.
/ PTO sprayer or 12v #33
For UTVs remember that if you are concerned about a spray tank that is as large as mine (100 gallons).....remember that you are not required to fill it full. I was thinking that was gonna be a huge load for my ranger but then I was like duh....just put 80 gallons in it or whatever. Gives you more Flexiblity with the extra capacity. Now if you have the kubota disregard....the 100 gallon is totally fine.....My ranger will squat before it rights itself with the self leveling suspension, but it is a load.
PALLET OF LOAD JACKS W/ CASTER WHEELS (A64278)
PALLET OF LOAD...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
2006 GMC T7 4X2 S/A SERVICE TRUCK (A66091)
2006 GMC T7 4X2...
2016 JLG 800AJ 4x4 80ft Articulating Boom Lift (A64553)
2016 JLG 800AJ 4x4...
2005 Chevy Suburban (A66408)
2005 Chevy...
Eagle Weather Vane (A64557)
Eagle Weather Vane...
