Strong grapple (last question i promise!)
/ Strong grapple (last question i promise!) #1
polemidis
Gold Member
Winthrop Maine
LS XG3140
I finished this grapple.
And did some FEM analysis, and revealed that I need to tweak it a little bit.
The only place that I am stuck and cannot analyse due to my software's limitation is the lid. Can anyone help me with his experience? What should be the thickness/size of a) the square tubing on the lid where the cylinder rod pushes? b) the thickness of the flat plates on the lids (the oily color)
I am pretty sure that the 2" x 2" x 1/8" sq. tube will be bent by the cylinder force. What you guys have? 1/4" or thicker? and the plates I have are 1/8". Should I make them 1/4"?? Obviously weight is our enemy on the FEL, I do not want to put anything more than I need. Like this the whole grapple is 432lbs (mostly made out of 3/8" steel). What do you guys have on your grapples plz?
I am one step before fabricating this monster. I think everything else is fine (well, in theory at least! :) )
/ Strong grapple (last question i promise!) #2
Well - I have in a grapple, what you are trying to stay away from - HEAVY. My Land Pride SGC 1560 weighs - 820#. The entire unit is 5/8" high carbon steel. Sooooo....... I would guess, 3/8" steel for the lid would be very adequate. My experience with this Land Pride grapple - it can be used for most anything short of a battering ram and suffer absolutely no damage. Its the type implement I can appreciate.
Your lid will only provide containment and very little, if any, support. However, you just might eventually use the lid for "breaking the soil" and back dragging to smooth/level an area. So consider those requirements when designing the lid - that's why I suggest 3/8" for the lid.
A suggestion - make the purple "arms" toothy on the top side, back to where they bend upwards and the yellow top arms toothy on the bottom side. Simple, small teeth will assist in holding any load more securely.
/ Strong grapple (last question i promise!) #3
Anxious to see your production model in action!!
I am too! I am logging all this winter and I have limbs everywhere. And I no longer try to pile the logs that I skid with the pallet fork, its so much pain. The grapple will make it 5x faster
But I still haven't figure out the square tube on the lid. Almost everything else is 3/8", the square tubing on the main body are 1/8", the lids most likely will be from 1/4". But the cylinder force will try to bent that square tube on the lid. I do not know if 1/4"will be enough there. Trying to get some input from you guys :eek::eek:
Sorry I have caused some confusion. Almost everything is 3/8" (the blues tines, gussets, hitches), the lids that are opening and closing (pink) are designed of 1/4", the oily plates from 1/8". My big question is the smaller brown square tubing on the lids (where the cylinder force is applied). 1/4" thickness? more? Excess weight is a big problem of course.
So I sent this nesting to the supplier just to get an estimate (I forgot 2 pieces!). The cutting service is $300, and the charge for a whole sheet (4'6'' x 8'8'') of 3/8" steel is $388 for mild and $447 for A572 gr50. Small difference I think. $70 dollars for a lifetime tool is not much. I may ask him for the next grade to see if it also small difference. For some reason it looks cheap! for only 10c/lb i think it worth it to build it from the stronger steel.
SO the whole grapple will be a HUGEEEEe savings project!!! I mean really huge! I already hear whispers saying "backhoe, backhoe" in my ear!! hahahahahah
/ Strong grapple (last question i promise!) #7
Get to cutting. Go with what you have figured. Performance should be great. If you tear it up so what you. you built it once. fix and move on.
/ Strong grapple (last question i promise!) #8
I was going to suggest losing the holes (or making them smaller) at the stress riser where the lower jaws turn, but I see you've done that. Looks like a fine design. You do this in Solidworks? Want to send me a resume, lol? We're always looking.
One last thought: I've never really understood the dual lid thing. Why not a single lid powered by two actuators? I think the holding force would be much better.
Not Solidworks, its expensive :( I am using Freecad v0.17
About the dual lid, the only reason is to be able to grab uneven stuff. Like picking up firewood from a pile, or maybe brush
About resume lol!! Its funny that I was just looking to craiglist about maybe put an ad to offer CAD design!! My resume is just one year "playing" around with CAD. I mean one year ago I didn't know what CAD was! :) :) :) But I love it. I mean I really love it! :) I will sent you a PM
/ Strong grapple (last question i promise!) #10
A single, wide lid can cause problems when grabbing a long log if it's not fairly straight & even: when the lid clamps down on one end of the log, it stops moving. The other end of the log may not be gripped at all, which allows that end to swing out of the grapple. This is why dedicated logging grapples tend to grab at three points (two on the bottom, and one from the narrow top). A wide single lid tends to pinch an uneven log at one point - the upper and lower grip one one end are right above one another
/ Strong grapple (last question i promise!) #11
We’re likely to end up in a another war here, but a wide single lid seems like the worst of both options. The advantage of single lid is lighter and cheaper. You just threw away both.
/ Strong grapple (last question i promise!) #13
What, maybe 3' of material @ double the weight? I'd go 1/4".
It will also help with some torque loading when one point of the lid contacts first (or only) like grabbing a stump or rock. If there ever was a tool designed to abuse, beside's a sledge hammer, it's a grapple. It seems your brain & common sense "disengage" almost completely while operating a grapple, you & your machine acquire perceived "Herculean" strengths. :laughing:
I'm looking forward to your build :thumbsup:
/ Strong grapple (last question i promise!) #15
Can not say the weight, I use the counterweight behind bucket with rocks.
Of course it could be easier, but I used a 10mm plate just in case.
Fortunately, not bent jet.:)
/ Strong grapple (last question i promise!) #16
Hello
Greetings from Estonia.
I also built a grapple myself.
Very good assistant on the farm.
TYM T433 HST - YouTube
Excellent video. Excellent design and construction.
Grapple increases your productivity dramatically.
Grapple also makes a lazy man, very little manual labor involved for cleaning up projects like you demonstrated.
Welcome to TBN!!!! Thanks for the video!!!!
/ Strong grapple (last question i promise!) #17
Watching your jaws clamp onto those rocks I didn't see any twisting or flexing at all. Very strong design!!!
/ Strong grapple (last question i promise!) #18
I built it mainly to push together and transport the branches and timber, but even the stones can be pushed out of the ground. The stones that you see in the video are pushed out of the deep ground.
This type of grapple really makes a person lazy :).
/ Strong grapple (last question i promise!) #19
Yes they will. I'll work a couple minutes trying to pick up something small that I could have easily done by hand. :)
/ Strong grapple (last question i promise!) #20
3/16 should work for the plates. 1/4 for the lid tube, I would bump to 3/16 for other tube as well. You'll experience tear out before twisting. 1/8 is just too thin for rough work. I'm an Engineer and I know the software says it will be fine but experience says you won't be happy. I'd also do doubler plates where cylinder attaches to lid and frame. High stress concentration. Also cut 3/4"-1" holes through your tooth doubles so you can rosette weld them together.
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2002 Suncoast 18ft T/A Enclosed Trailer (A61569)
2002 Suncoast 18ft...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2016 Land Rover AWD SUV (A61569)
2016 Land Rover...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
2019 CATERPILLAR 262D3 SKID STEER (A62129)
2019 CATERPILLAR...
