Buying Advice contemplating a 5610
/ contemplating a 5610 #1
scrantchy
Monroe
1998 Deere 5310
Hi everyone, I see municipalities using toolcats all the time, never saw a 5610 though. before i got serious about one, i'd thought I get some opinions here. I do firewood, flail mowing and snow removal for myself and a few homes on my road. No Ag work. I use a p/u for plowing and a Deere 5310 utility tractor to move snow and blow it when I run out of room. I also skid wood with a small Farmi winch.
How is the toolcat's pto? The winch only needs 25 hp and that would be the only thing I would use it for. Iv'e looked at low profile compact tractors and it seems none have a front pto option or enough power to use hydraulic implements. Is there anything else out there?
Let me rephrase my scatterbrained post. How do think the 5610 would work for light skids with a logging winch attached to it's pto? It would be done on previously made skid roads.
/ contemplating a 5610 #5
The only thing I have used on the PTO is the neighbor's post hole digger with a 9" auger. And it did fine in the red clay here.
The Toolcat will easily lift more than the 1500 pound rating on the loader. It gets used mostly with the 7', 1800 pound brush hog:
That's one mean lookin mower!!
/ contemplating a 5610 #8
Yep, and the blades are sharpened on both edges. I use normal rotation for the pasture and reverse rotation for brush. :thumbsup:
It sure looks like the Cadillac of UTV's and I'm having trouble deciding since there are so few used ones around and even those are within 10k of a new one. Also you can get get a lot of tractor for 60k. My closest Dealer is 3 hrs away and has a new one in stock. I've got to get out there to get the bug.
/ contemplating a 5610 #10
why change rotation for bush or grass? does it not just change the side the blades cut on?
/ contemplating a 5610 #11
He sharpens both sides of the blades so you have a fresh sharp cutting edge when you change directions. Trees and brush dull the blades faster so if your cutting both, you dull the one side of the blade on the harsh stuff and still have plenty of sharp blade left for the grass and you can switch back and forth depending on you mowing situation.
DEWFPO
/ contemplating a 5610 #12
thanks, figured I was missing something, good idea if the cutter is hydraulic driven, lasts twice as long between sharpening
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2019 HINO 258A (A60736)
2019 HINO 258A...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
