The WICKED Root & Debris GRAPPLE!!!!!!!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,161
Oily rags wrapped on hydraulic cylinder shafts help protect them from rusting/getting scratched... When the lids are closed, (which is the 'normal' way to store the grapple-bucket) the shafts are exposed, so I keep them covered/wrapped... I put that pic in there as a reminder...
I'm new to this, but I always wondered why hydraulic implements are stored
with the shafts exposed instead of in the closed position.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,162
It's for safety. Walking into an open grapple hurts more than walking into a closed one. Same with raised loaders vs lowered ones. Also a raised loader (or any weight on a cylinder) will bleed down over time. If you lower it when you park the tractor you won't accidentally put something under the loader and come back later to find the bucket resting on it. Same with the 3pt.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,163
better question is who stores there implements on carpet!:shocked:
I know TBN loves the wicked grapple, but really a tractor implement that gets stores on carpet with a nice oil soak blanket on top.... really?
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,164
It’s better to store it with the shafts in because they’re in oil and protected from the elements. My grapple gave trouble to reconnect the couplings like that though. I had best results with the lids closed and bleeding the pressure off before disconnecting. My backhoe never gave trouble to reconnect and I tried to keep as much cylinders as possible retracted on it.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,165
I assumed that was the reason. That a good tip Thanks Bill
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,166
Good tip.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,167
I've been busy at work and haven't had a chance to post here in a bit. I found a new way (to me anyways) to use my Wicked Twin. Instead of getting off and changing bucket/grapple/bucket/grapple ect doing a back fill the other day I just grabbed the bucket in the grapple and gave it a try. (insert epiphany here) It was a cold, blowing day so I didn't mind staying in the cab as much as possible.
Turns out I can scoop/haul/blade loose material really well by just grabbing the bucket in the grapple and using it almost like it was attached normally. I say almost because the bucket does move around some in the grapple. There is also an advantage in back dragging with this set up. The tines in the floor of the grapple hold quite a bit of loose dirt similar to a mini land leveler. If there is a little loose dirt it does a faster/cleaner final grade. WIN-WIN!!!
In this instance I was having to back fill and level a bit then drop the bucket to pickup roots/limbs that were coming to the surface and getting in the way of a good final grade. Just grabbing the bucket made the job go faster and easier on me. Smarter not harder!
All these uses for the Wicked Twin makes me wonder what else it can do!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,168
Quality shafts are hard chromed and take many, many years to rust in most environments. I have seen some 50 year old cylinders that are just fine, especially if they have been used occasionally.
I did trade for a 12' disc a month or so ago that had a slight rust spot on the chrome shaft. The original hoses were rotted to the wire and stiff enough that they aren't very flexible. The hose fittings were rusted beyond use. The disc was probably built in the '60's or 70's and set outside all its life.
That being said, by laying an oily rag on them they and the seals they ride on will probably last indefinitely.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,170
Welcome Back!!
This calls for a new chapter in the Wicked uses book.
*SMARTER Not HARDER*
I like it. :thumbsup:
Here's another quote I read and enjoyed recently. :laughing:
Travis
"The land pride grapple loves to have bent teeth that eventually fall off. The Everything Attachments grapple and teeth is tougher than woodpecker lips."
From the EA Channel Facebook Group:
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,172
I store the tractor/implements (and a few other pieces of farm equipment) in a 60' X 40' X 15' steel-trussed pole barn... Both sides have hanging/drive-through sun-shades (also helps to keep out leaves/birds/dust/etc. and you can't see through it from any distance) and the ends are open (except the gables are closed)... I did not want to put in a solid concrete floor yet I wanted to do something that would give me a cost-effective/efficient surface for ease of maintenance and working on equipment... I used several inches of 70% sand/30% clay-mix as a compacted base (under the pole barn and out/past the drip-line) and then laid 2 layers of USED commercial carpet... I have a good friend who is in the flooring business and I can get all the used/removed (and some new 'end-of-roll') carpet sections I want FREE... NOTE: When removing the old carpet most flooring companies cut it into manageable/lighter-weight sections/strips, which are still usable but try to get the largest pieces possible... Beware they will be VERY HEAVY... Old/used commercial carpet makes a GREAT surface to store equipment and to work on and is easy to keep relatively clean with a good/strong blower and cost next-to-nothing... I purposely included such pics to share my idea... If it helps/works for YOU, then good-on-ya lad...
As far as the exposed cylinder rods go, of course if I could store them such that they weren't exposed I would... However, as I mentioned and shown in the pic, the configuration of some 'stored' hydraulic equipment is such that some of the cylinder-rods may remain partly/fully exposed... So I WRAP them in oily rags which protects them from rust AND physical damage...
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,173
VERY slick... I notice the fully enclosed cab, the fact that you say it was cold/blowing yet the ground is nowhere near frozen, I assume you have the heater/stereo on, you are wearing your favorite wooly-tights, prolly sipping latte/eating donuts, don't want to get out of the cab because you still have your bedroom slippers on, and you are doing a little 'critical' landscaping avoiding the Mrs./honey-doo stuff... Got to hand it to you Lad, YOU got it figured out... NOTE: This friendly ribbing is coming from someone who is currently in Central Florida where at 2130 hrs. it is still 74* ;+)... Just a little respectful jocularity... Thanks for the GREAT idea...
Maintain course/speed...
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,174
free.. is free... and I cant argue against it. sounds like a very cost effective way of making your life a little nicer. Where' I'm at the frost and rodents would kill the idea of carpet over sand/clay.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,176
Nice job!
Nice to have the ability to grub and cut brush, grapple logs, load and spread dirt with the bucket, AND use a box blade - All while never leaving the seat! :D
#WickedArmyGrapple
LMFAO... LMFAO... LMFAO...
Can't wait to see the next iteration... Not sure I can add to this...
GREAT come back... Never knew grappling could be such fun/entertaining/resourceful...
A customer from Missouri just sent in this review of his 55" Single Lid Wicked Utility Grapple for tractors up to 75hp. He has it installed on a Kioti RX7030.
"So far I am impressed with this unit. Am stepping up from a 48" grapple on a 50 HP tractor to this unit on a 74 HP tractor.
I researched grapples for several weeks before pulling the trigger on this one. The build quality is very good, beautiful in fact. The single lid is a personal preference as is the narrow width for the type of work I do.
The geometry on this grapple is optimum. The bottom tines are long enough to get under quite a bit of material as contrasted with the clamshell style. The lid has an extremely generous opening which is important when getting a big "bite". The lid has serrated semi circles that make it possible to grab a log end on to drag it out of the woods to an open area which is very nice compared to my old unit where I had to try and engage a tine on the lid and hope it didn't slip off.
Also has been wonderful for moving rocks.
So far it has been an excellent value."
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,178
I have heard that Stormy Daniels wears a Wicked necklace, is she your new spokesmodel? I am told she does anyway. :confused3:
She could sell a lot of your big dual lid grapples :D
/ The WICKED Root & Debris GRAPPLE!!!!!!! #3,179
I just ordered my 72" dual lid from EA today. Looking forward to some serious tree removal around my field edges. I've also got a lot of downed trees and brush to clear in the timber. My timber is impassable in many areas as there hasn't been any livestock ran in about 40 years. Trying to improve the hunting and overall appearance. Travis at EA was a big help.
:laughing: I'm not scared of much, but this one frightens me a little(my wife could be watching). :laughing:
Travis
HYUNDAI HLF25C11 (A60736)
HYUNDAI HLF25C11...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2006 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2006 BIG TEX 20...
17601CFL (A59228)
17601CFL (A59228)
1988 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1988 Lufkin...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
