Backhoe financing
/ Backhoe financing #21
How do those of you with cab tractors like the backhoe? It seems like that would make it a less appealing option. For that matter 13k makes it a less appealing option. I bought my BH-90 for 4K used.
Cab changed my life for the better for the past 5 years - never looked back. My backhoe was 9K brand new and installed....very happy
/ Backhoe financing #22
Speaking of cab. Can you open the window of the tractor and sit on the seat to run the hoe ? Curious how much head clearance there is in case you wanted to listen to the radio while digging
/ Backhoe financing #23
Nope- have to get out and go around back and climb on the backhoe which has it's own seat.
/ Backhoe financing #24
My inclination would be to leave it in low turtle, defeat the seat safety switch. Then attach a stick/linkage to the go pedal & loader joystick to operate things from the how seat. Would work for trenching or minimal adjustments in a straight line. Not likely to be useful for any other than lifting the loader & going straight.
/ Backhoe financing #25
I do understand for moving the machine, having to jump in the tractor. Just curious if you could have the rear window open to listen to the radio.
/ Backhoe financing #26
I'll try it out and let you know....once it quits RAINING here!
/ Backhoe financing #27
Awesome !!! I am anxious to hear / see....
/ Backhoe financing #28
Any update to see if you can sit in the seat while rear window open ?
/ Backhoe financing #29
Yep- doesn't work. The rear window sits too low when it's flipped up- seat is too close to it
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
2018 Ford F-150 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2014 Ford F-550 Mason Dump Truck (A61568)
2014 Ford F-550...
2013 Ram 1500 Crew Cab Pickup Truck (A61568)
2013 Ram 1500 Crew...
New/Unused 3 Point Ball/Flat Hitch (A61166)
New/Unused 3 Point...
