Backhoe financing
/ Backhoe financing #21
How do those of you with cab tractors like the backhoe? It seems like that would make it a less appealing option. For that matter 13k makes it a less appealing option. I bought my BH-90 for 4K used.
Cab changed my life for the better for the past 5 years - never looked back. My backhoe was 9K brand new and installed....very happy
/ Backhoe financing #22
Speaking of cab. Can you open the window of the tractor and sit on the seat to run the hoe ? Curious how much head clearance there is in case you wanted to listen to the radio while digging
/ Backhoe financing #23
Nope- have to get out and go around back and climb on the backhoe which has it's own seat.
/ Backhoe financing #24
My inclination would be to leave it in low turtle, defeat the seat safety switch. Then attach a stick/linkage to the go pedal & loader joystick to operate things from the how seat. Would work for trenching or minimal adjustments in a straight line. Not likely to be useful for any other than lifting the loader & going straight.
/ Backhoe financing #25
I do understand for moving the machine, having to jump in the tractor. Just curious if you could have the rear window open to listen to the radio.
/ Backhoe financing #26
I'll try it out and let you know....once it quits RAINING here!
/ Backhoe financing #27
Awesome !!! I am anxious to hear / see....
/ Backhoe financing #28
Any update to see if you can sit in the seat while rear window open ?
/ Backhoe financing #29
Yep- doesn't work. The rear window sits too low when it's flipped up- seat is too close to it
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
Ford Pickup Truck Bed (A61568)
Ford Pickup Truck...
240 Massey Ferguson Tractor (A61165)
240 Massey...
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
