John deere alternator wiring
/ John deere alternator wiring #1
Joe Cannon
Walterboro, SC
04 John deere 2210
I just bought a used 04 2210 and the wires out of the alternator were taped together (connector was cut off) tape came off and rubbed frame and after putting meter on it..its toast ..my question is ...How do I know what wire goes where? There is a stripe on the green wire going from the wiring harness but both wires on alternator are green..I ordered a new alternator so It will have the connector on it. if I knew what wire coming out of the harness went where ....thanks
/ John deere alternator wiring #2
Like everyone else is about to tell you, you need to get a service manual. The schematics will have the color codes and the manual usually shows the connectors and pin outs. If not the alternators are usually marked on them.
/ John deere alternator wiring #3
The 2210 uses a dynamo type of alternator. It puts out AC voltage. It won't matter which way the wires go in the connector at the alternator.
Thank you ...now to find out where and how it is rectified lol but that I can find Thanks again
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
(1) 15.6-28 TIRE & WHEEL (A62131)
(1) 15.6-28 TIRE &...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
Teak Wood Table Top (A61569)
Teak Wood Table...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
1978 Ford L8000 Fuel and Lube Truck (A61165)
1978 Ford L8000...
