John deere alternator wiring
   / John deere alternator wiring #1
Joe Cannon
Walterboro, SC
04 John deere 2210
I just bought a used 04 2210 and the wires out of the alternator were taped together (connector was cut off) tape came off and rubbed frame and after putting meter on it..its toast ..my question is ...How do I know what wire goes where? There is a stripe on the green wire going from the wiring harness but both wires on alternator are green..I ordered a new alternator so It will have the connector on it. if I knew what wire coming out of the harness went where ....thanks
   / John deere alternator wiring #2
Like everyone else is about to tell you, you need to get a service manual. The schematics will have the color codes and the manual usually shows the connectors and pin outs. If not the alternators are usually marked on them.
   / John deere alternator wiring #3
The 2210 uses a dynamo type of alternator. It puts out AC voltage. It won't matter which way the wires go in the connector at the alternator.
Thank you ...now to find out where and how it is rectified lol but that I can find Thanks again
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2004 Dodge Ram 1500 4x4 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
