John deere alternator wiring
   / John deere alternator wiring #1
Joe Cannon
Walterboro, SC
04 John deere 2210
I just bought a used 04 2210 and the wires out of the alternator were taped together (connector was cut off) tape came off and rubbed frame and after putting meter on it..its toast ..my question is ...How do I know what wire goes where? There is a stripe on the green wire going from the wiring harness but both wires on alternator are green..I ordered a new alternator so It will have the connector on it. if I knew what wire coming out of the harness went where ....thanks
   / John deere alternator wiring #2
Like everyone else is about to tell you, you need to get a service manual. The schematics will have the color codes and the manual usually shows the connectors and pin outs. If not the alternators are usually marked on them.
   / John deere alternator wiring #3
The 2210 uses a dynamo type of alternator. It puts out AC voltage. It won't matter which way the wires go in the connector at the alternator.
Thank you ...now to find out where and how it is rectified lol but that I can find Thanks again
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 Club Cadet ZT1 54in Zero Turn Commercial Mower (A50322)
2019 Club Cadet...
2013 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2013 Ford F-450...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
