Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,561
Can anyone do this with pallet forks?
YES... With my matching grapple. NO problem at all...
Can you do this?
How about drive/push your grapple straight into the ground, under a big rock, grappling it and pulling it out of the ground??
NO problem at all, for pallet forks with matching grapple...
I could go on, but I think you get the point...
SR
/ Grappling fun - A Picture Thread.... #1,562
This is a Log grapple:
Pictures from an image search.
I would like to have that setup on the BACK of my tractor. (Preferably with a matching hydraulic winch.)
Pallet forks with a "matching" grapple work perfectly for that use...
From time to time, I use mine just for that purpose...
SR
As effectively as a root grapple? if so I may reconsider my next purchases. I don't have a few stumps... I have eleven piles stacked 10 feet tall and about the same in diameter. The stumps are all different sizes, and I suspect there are quite a few large rocks mixed in.
It's going to be a major project this summer reclaiming the soil, then using the debris to fill a low area.
/ Grappling fun - A Picture Thread.... #1,563
andy i use forks where appropiate
can your forks do this?
maybe/probably as easily?
i doubt it
can your forks clear this?
forks have their place, so does a grapple, and there is not one type of grapple that is best for all situations.
rob i do stack bales and grub rocks with mine, though i prefer a bale spear for bales. and we don't have many rocks here but i can do similar with stumps though forks or a smaller grapple work better
/ Grappling fun - A Picture Thread.... #1,564
Can you do this?
Yep, but I use a bale spear on the 5x6 bales:
SR
Yep, with the 6' wide Monster Grapple:
Don't have to get under it, just pop it up:
Clamp on and pick it up:
/ Grappling fun - A Picture Thread.... #1,565
/ Grappling fun - A Picture Thread.... #1,566
i doubt it
(Some photos deleted.)
What year is your Ford truck? A couple of better pictures might be appropriate. :D
/ Grappling fun - A Picture Thread.... #1,567
View attachment 538475 View attachment 538476 View attachment 538477 View attachment 538478
It's NOT about IF the machine will do the work, it's about whether or not pallet forks with a matching grapple will do all the work posted here...
My experience is, YES, my pallet forks with matching grapple is one tool that replaces all the tools shown here. I can leave it on and do all the jobs shown here, AND pick some BIG rocks, that are down into the ground, not those little flat rocks shown in the pict...
So far, I haven't seen anything here that my tool won't also do, so why buy several tools to replace one?
Try this with your grapple,
SR
/ Grappling fun - A Picture Thread.... #1,568
/ Grappling fun - A Picture Thread.... #1,569
SR
I have seen that done with a root grapple; my neighbor put vinyl siding on his entire building. My question isn't whether it can be done; rather, can it be done efficiently on a large scale project such as what I'm facing this summer. And with all due respect, your equipment is much bigger than tractors which many of us own.
/ Grappling fun - A Picture Thread.... #1,570
Back to grappling fun. Using a grapple to spread ashes and red clay that was on root balls, from the last burn:
The view from the seat:
/ Grappling fun - A Picture Thread.... #1,572
that's because your tractors are tinker toys
Yep, here is a picture of my first Versahandler, before I drove it out of the box and started grappling cedar trees with it: ;) :D
Here it is in action back in 2010:
/ Grappling fun - A Picture Thread.... #1,573
My tractor is a tool to suit my needs; not to impress you or anybody else. I don't really care if your *.* is bigger than mine.
/ Grappling fun - A Picture Thread.... #1,574
Try not to feed the trolls. I know I can't help myself sometimes either. He'll burn out and disappear soon enough. :drink:
For big piles of stumps and soil to sort I'd think hard about a wide, curved-bottom, two-lid grapple, with fairly wide tooth space. And you probably don't need a heavy, HD one either thus saving lift capacity you'll need. :2cents:
Edit: wide for efficiency. Two lids for big irregular stumps. Wide spacing to sift out soil.
/ Grappling fun - A Picture Thread.... #1,575
Bring your tractor over and we’ll run head to head. IMG_9951.JPG After we get done with that we’ll try raking debris. I get a grapple ( the tooth bucket actually works better) and you get a pallet fork grapple. IMG_9953.JPG
/ Grappling fun - A Picture Thread.... #1,576
Thanks on both points. In all of my years online (since 2001) I had never even considered blocking anybody until today.
More importantly I hadn't thought about what to get for a grapple beyond the point of needing one, so you have gotten me thinking in that direction.
/ Grappling fun - A Picture Thread.... #1,577
Sawyer Andy lists a Farmall M which is a really cool tractor but not a beast. I am not sure why the post
/ Grappling fun - A Picture Thread.... #1,580
So do you have a grapple or grapple forks for it? Why don’t you leave? You’ve made no meaningful contributions and have been trouble for the start. And you’ve only got a tinker toy loader. Try comparing it to a 988 cat or bigger.
UNUSED JCT HYD TRENCHER (A62131)
UNUSED JCT HYD...
(APPROX.25) 2"X4"X40" TUBING (A62130)
(APPROX.25)...
2014 JOHN DEERE 323E SKID STEER (A62129)
2014 JOHN DEERE...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
Ratchet Straps (A61569)
Ratchet Straps...
