Bush Hog vs Woods vs.....?
/ Bush Hog vs Woods vs.....? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
Finally measured the rear wheel width on my new MX5800. Looks like I'm around 81" at a minimum, so I can go with an 84".
I was a tad surprised on the cost of the units below - I found them a couple hundred cheaper but I had these numbers written down from one local shop.
84" rotary cutters, slip clutch:
Bush Hog BH17 - $3,650
Woods BB84X - $3,900
Brand XYZ??? - $?,???
(I believe this is all without chains.)
Looking at the spec's, they are pretty much the same - I think the Woods is 11ga deck vs 10ga deck on the BH. More focused on tail wheel design at this point.
Either way, I think these are pretty stout units and I won't be using them much in a year.
/ Bush Hog vs Woods vs.....? #2
I would stay with a nice HD 72" model myself.
/ Bush Hog vs Woods vs.....? #3
2" cutting capacity and ~1000# for a 7' single spindle......neither I would consider an HD cutter. More like medium duty.
Which may be just fine.....but what do you intend to cut with it and how often? IF you are frequently mowing a pasture......either would be fine. IF you plan on mowing down land that has sat untouched for 5-6 years.....I'd want something with a little more heft.
If just doing pasture maintenance.....have you considered an 8' twin spindle cutter?
/ Bush Hog vs Woods vs.....? #4
I've been checking cutters for a couple years. Maybe one of these days......
JMHO, but - I would go down in cutting width and up in structural strength. I have a 2009 Kubota M6040 - 64 hp - I'm thinking something like a Brown 415 cutter. I could easily handle the Brown 416 or 417 but, and that's a big but - I really don't want that much weight or such a big structure out back swinging around as I'm trying to dodge around trees, rock, stumps etc. I'm more than willing to accept the fact that the rear tires are going to stomp down some grass/brush that I may not catch with a narrow mower. I simply like the FACT - if my big 'ol rear tires will clear the object, be it rock, tree or dirt mound, most likely so will a 60" cutter.
I was liking the idea of a 72” originally as well. My hesitation is that I would use this mower to mow around my pond. It’s a natural pond and the banks are too steep to get remotely close to the water, so a shorter cutter would mean I’d lose another 6” from where I am comfortable mowing now. (With my B3200 last year with a 72” Woods Finishing Mower)
All I will be cutting with this is grass and whatever weeds pop up. Last year I was mowing part of the area with my F3990 – there are no rocks, stumps, small trees etc to worry about. I do not want to mow it with my F3990 because I try to cut that area only every 1 -2 months, depending on the weather. If the ground is soft – I can’t mow because of the slope – the ground will just give out and start the slide. Last year because of rainy weather, I went longer than 2 months and was probably mowing 5 – 6 ft tall vegetation. I knocked it down with my F3990 in 2 or 3 passes – the F3990 is like a goat, very nice on slopes.
The amount of land is minimal, so I do not need a large cutter or a bullet proof one (i.e. I’m not making trails in the woods, etc). Strictly maintenance. I was looking strongly at an offset cutter or flail but that seems to automatically add another $2,000 (minimum) to the price tag – hard to justify that.
/ Bush Hog vs Woods vs.....? #7
agree with those who suggest 72" cutter a 7' hog is unusual. usually people jump from a 6' to an 8' twin spindle. once owned an mx5000 and would not consider a 7' esp around the pond banks.
for your own safety, get a heavy duty walk behind mower for that, works like a charm for me. to me a 6' heavy duty model would be my choice. imho trying to squeeze and extra 6" for the slopes is asking for trouble on a mid compact tractor like the mx series best of luck, stay safe :thumbsup:
/ Bush Hog vs Woods vs.....? #8
All I can tell you is, Woods is the cutter that you hear LESS about problems with, than the other brands in this price range, especially when it comes to the gear box...
In the price range you are looking, for MY money the Woods Brush Bull IS the best rotary cutter...
We have two Woods cutters and both have been very reliable...
SR
/ Bush Hog vs Woods vs.....? #9
Just reading your statement - getting close to the edge, it makes me shiver. If I got too close to the edge on my little lake - its a 40' drop, off the basaltic lava cliffs before I would hit the water. I couldn't care less about what grows on the edges of my little lake - I make a conscious point to stay back at least 100' from the edges with ANY mechanical device.
Looks cold this time of year - it is........
I'm being safe as possible, I should have clarified the the 'edge' that I mow to is where I feel comfortable on the machine. Anything past that, I don't feel comfortable and don't bother with.
Sawyer - I've only owned Woods equipment in the past, Brush Hog isn't terribly common around here - I've only been able to find one Bush Hog dealer - so I have a comparison. I've had no issues with my previous Woods equipment but I thought it never hurts to look....especially during the winter when I'm not using the equipment anyway.
/ Bush Hog vs Woods vs.....? #11
I used a 6' Rhino TW72 heavy duty cutter for about 15 yrs and literally beat the crap out of it. I couldn't tear it up no matter how hard I tried. I sold my larger tractor, NH TN75, and the Rhino went with it. Darn fine piece of equipment in my mind.
Just to give an idea of inflation, I bought it around 20 yrs ago for $1500.
The pricing that I listed before was from our local Rhino dealer. However, by "dealer" I mean that they can order a unit but do not stock them and push Bush Hog and Woods over anything else. I do like what I saw on Rhino's site, so I'll have to see if he can get me a price on a unit.
/ Bush Hog vs Woods vs.....? #13
I also would suggest a 6' unit...but if you go to 7' (or larger), you'd be making a mistake to get one without twin tail wheels...keeps the unit well balanced and since you are'nt gonna cut down the woods, give a very good even cut. As previously noted, as far as cost, I've had mine (an IMC, which isn't made any more) since '03 and paid right at $1400 for it...not sure how you determine HD, but it weighs over 1K lbs. BobG in VA
Woods has the
BB72X
BB720X
BB7200X
The BB72X is a Cat 1 connection. Up to 2" and up to 65 Tractor HP. 11ga deck and side skirt. 804lbs.
The BB720X is Cat 1 & 2 connection. Up to 3" and up to 120 Tractor HP. 10ga deck. Replaceable skid shoes. 1,200lbs
/ Bush Hog vs Woods vs.....? #15
I can vouch for the quality and durability of both the Woods BBX72 and Bush Hog 3008 cutters.
Chains needed or are the "standard" deflectors okay?
$2,450 for the BB72X w/ chains
$2,100 w/o chains
/ Bush Hog vs Woods vs.....? #18
My next rotary cutter WILL BE a Woods BB720X, I haven't seen anything in it's price class that's built as well, with as good of a reputation for lasting!
SR
I like the BB720X but it's probably way more than I need for my application. I like how much more heavy duty it looks over the BB72X
/ Bush Hog vs Woods vs.....? #20
I’ve got a Woods BB720x that I run on my JD4066R. It’s my 3rd rotary type mower...the other 2 being 60” JD machines. I’ve got to say, the Woods takes it to another level. The BB720x is big and heavy, but does a great job, and by all accounts will outlive me. I wouldn’t want anything bigger unless I had a much bigger tractor.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
2023 John Deere 333G Track Loader (A63111)
2023 John Deere...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
LILLISTON 2R ROLLING CULTIVATOR (A63291)
LILLISTON 2R...
