Ballast Ballast box slash tool box
/ Ballast box slash tool box #1
tomplum
Elite Member
PNW
XJ2025H
And if you act in the next 30 minutes, you can throw your chain in the back for free!
/ Ballast box slash tool box #3
Nice!
What color is the paint? Looks like a real good match
Giant schmiant! It needs to be 4 times bigger. The box itself is 250. The filling is sand/ pea gravel plus some steel scrap should make it approach 800. That would be close to the hoe. Thinking about what you said the hoe is what it needs, that was my target anyways. :drink: No trap door, so if I want it lighter- it gets a hole burned in it....
Rustoleum safety blue. I'm not the best painter. In applying it @ 45 degrees, I thinned it slightly and it mostly dried in a few days. I have the cover popped open to help it finish. (Hopefully) Thanks for the kudos guys.
skid plate to protect the suction filter, hot off the press.
Did this awhile ago. Frankenstein camera monitor mount. Needs a larger anti glare shield or maybe the angle brought back some.
/ Ballast box slash tool box #8
its purdy too! Good work, how heavy did it come out to be do you think? Your giant shop makes your tractor look small :)
Only 4 cup holders!?!?. What were you thinking? 😀
But seriously that looks nice. I need to do something like that to my tractor too.
/ Ballast box slash tool box #9
Nice. Just a straight bolt-on addition the way you made it? I can see that potentially avoiding a heck of a headache!
Not so much. Holes will be drilled. There isn't much to mount to there. There are 2 round bosses which is likely for a clutch pedal or pivot on a geared model. The back is pretty well protected, but the front could grab something in the rough.
Only 4 cup holders!?!?. What were you thinking? ��
Cup holders. Darn, I missed something. Let's see 1) cooler 2) cup holders 3) chain saw receptacle...:drink:
guess you'll have to give me that one and build a new one with the 3 additions :D
I think the freight would kill us!
SnowEx Rotary Broom SS4000 (A64047)
SnowEx Rotary...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2010 Unverferth 1225 Rolling Harrow (A63116)
2010 Unverferth...
AGROTK Tire Changer (A62183)
AGROTK Tire...
