Ballast Ballast box slash tool box
/ Ballast box slash tool box #1
tomplum
Elite Member
PNW
XJ2025H
And if you act in the next 30 minutes, you can throw your chain in the back for free!
/ Ballast box slash tool box #3
Nice!
What color is the paint? Looks like a real good match
Giant schmiant! It needs to be 4 times bigger. The box itself is 250. The filling is sand/ pea gravel plus some steel scrap should make it approach 800. That would be close to the hoe. Thinking about what you said the hoe is what it needs, that was my target anyways. :drink: No trap door, so if I want it lighter- it gets a hole burned in it....
Rustoleum safety blue. I'm not the best painter. In applying it @ 45 degrees, I thinned it slightly and it mostly dried in a few days. I have the cover popped open to help it finish. (Hopefully) Thanks for the kudos guys.
skid plate to protect the suction filter, hot off the press.
Did this awhile ago. Frankenstein camera monitor mount. Needs a larger anti glare shield or maybe the angle brought back some.
/ Ballast box slash tool box #8
its purdy too! Good work, how heavy did it come out to be do you think? Your giant shop makes your tractor look small :)
Only 4 cup holders!?!?. What were you thinking? 😀
But seriously that looks nice. I need to do something like that to my tractor too.
/ Ballast box slash tool box #9
Nice. Just a straight bolt-on addition the way you made it? I can see that potentially avoiding a heck of a headache!
Not so much. Holes will be drilled. There isn't much to mount to there. There are 2 round bosses which is likely for a clutch pedal or pivot on a geared model. The back is pretty well protected, but the front could grab something in the rough.
Only 4 cup holders!?!?. What were you thinking? ��
Cup holders. Darn, I missed something. Let's see 1) cooler 2) cup holders 3) chain saw receptacle...:drink:
guess you'll have to give me that one and build a new one with the 3 additions :D
I think the freight would kill us!
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2022 John Deere Z920M Zero Turn (A63116)
2022 John Deere...
Adams Under Truck Conveyor (A63118)
Adams Under Truck...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
Bobcat T650 Compact Track Loader (A64047)
Bobcat T650...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
