CK2610 rear blade size?
/ CK2610 rear blade size? #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
Can anyone tell me if you can rotate at 6' rear blade on the 2610 without removing from the 3pt? I'm looking at a Bush Hog 50-06. I need the swing offset to clean ditches without getting too close to the edge of the road:eek:
/ CK2610 rear blade size? #2
With a 6' blade I would say yes for sure, but why not get a 7 footer? Your tractor will handle a 7' rear blade fine. With a 7' you need to really check to be sure, my guess is yes the blade can be turned 360* when the boom is straight back. ;)
/ CK2610 rear blade size? #3
Also depends on the blade , I’ve seen some of the cheaper lines that will not turn due to the main beam being short.
/ CK2610 rear blade size? #4
Even with a 6' blade? I know wider than 6' starts to become a problem for the more economical units, but I have never seen a 6' blade that would not turn 360". You would have to have something like a 30" boom and I think that 36" is about the shortest that I've ever seen on any full cat 1 units.
I will have to see if I can get a look at a Bush Hog 50 series blade am measure the beam. I had a 5 footer on my 2510 and could rotate it with no problem.
/ CK2610 rear blade size? #6
I have a 7' woods on my CK25 and I can turn it all the way around. It takes a little "finesse" , but doable. I think a 6' blade is too short.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 FORD F250 (A60460)
2013 FORD F250...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
iDrive TDS-2010H...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
