CK2610 rear blade size?
   / CK2610 rear blade size? #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
Can anyone tell me if you can rotate at 6' rear blade on the 2610 without removing from the 3pt? I'm looking at a Bush Hog 50-06. I need the swing offset to clean ditches without getting too close to the edge of the road:eek:
   / CK2610 rear blade size? #2
With a 6' blade I would say yes for sure, but why not get a 7 footer? Your tractor will handle a 7' rear blade fine. With a 7' you need to really check to be sure, my guess is yes the blade can be turned 360* when the boom is straight back. ;)
   / CK2610 rear blade size? #3
Also depends on the blade , I’ve seen some of the cheaper lines that will not turn due to the main beam being short.
   / CK2610 rear blade size? #4
Even with a 6' blade? I know wider than 6' starts to become a problem for the more economical units, but I have never seen a 6' blade that would not turn 360". You would have to have something like a 30" boom and I think that 36" is about the shortest that I've ever seen on any full cat 1 units.
I will have to see if I can get a look at a Bush Hog 50 series blade am measure the beam. I had a 5 footer on my 2510 and could rotate it with no problem.
   / CK2610 rear blade size? #6
I have a 7' woods on my CK25 and I can turn it all the way around. It takes a little "finesse" , but doable. I think a 6' blade is too short.
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
2005 UD Truck UD1300 Landscape Dump Truck (A56858)
2005 UD Truck...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
