camp house floor insulation
/ camp house floor insulation #41
That is going to be about the easiest, best and most economical way to go there, joe. You can't go wrong at $8/sheet either. Makes insulating with open bat insulation very easy.
/ camp house floor insulation #42
I have a 10x12 building on 10x10 posts that has floor insulation, and it's above ground enough to get under and work. when it was built
15 years ago they put 1/2 PT plywood on and fiberglass insulation, but over the years some corners and seams opened up, and critters had access. i have been working on fixing, by using
any scraps i have around to screw things back together. i would recommend a good solid strip below the plywood along all of the seams if possible.
/ camp house floor insulation #43
I would install blocking at all of the seams so that you can nail the plywood on all the edges. That way you know that the seams will stay lined up with no chance of warping.
/ camp house floor insulation #44
I built a 28X36 hunting/recreation log cabin on piers about 15 years ago. I cut trees off the property and had a local guy bring in his portable mill and cut 6X7 logs. I didn't put any insulation between the joists. My reasoning was it's just a hunting cabin, and it will serve my purposes. It's mostly carpeted so the floor isn't uncomfortable. It has a wood stove that keeps it pretty toasty even in cold weather. It has served my purposes quite well, but that said, I wish I had put insulation in. I wasn't on TBN back then. Wish I had been and had asked lots of questions of you experts. I was an inexperienced builder, but all in all, it has held up well.
/ camp house floor insulation #45
that too
/ camp house floor insulation #46
The best thing about TBN is somebody will come up with something that you never thought about doing, or even considered. I can't count how many times I've started a project, thought I knew what I was going to do, then realize that a comment on here will change everything!!!!
/ camp house floor insulation #47
As above and after being on a few other forums.... We are very respectful to each other for the most part. I like that!
/ camp house floor insulation #48
I just skimmed this thread, so not sure if someone has already mentioned this. If you go onto YouTube and check out "Boss of the Swamp" you will hear him swear by multiple times about a product for this exact purpose.
Shop Reflectix 2-sq ft Reflective Roll Insulation (24-in W x 1-ft L) at Lowes.com
This Bubble foil must the same thing as that Lowes link and that youtube video you mentioned.......... HOW TO INSULATE A CABIN FLOOR AND KEEP IT RODENT FREE - YouTube
2 years later, the camp house is almost done.
/ camp house floor insulation #50
Ramp looks nice. Elderly people will appreciate that.
New Holland 3930 (A60462)
New Holland 3930...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
