Thread Start Date
/ Thread Start Date #1
TractorGuy
Elite Member
N. FL
John Deere 4410, John Deere 4120, Kubota LX3310 cab, John Deere F725 Front Mount Mower, Swisher 60" pull behind mower. John Deere 4310 CUT (sold), Ford New Holland 575E Cab Backhoe (sold).
I go to some forums that list the thread start date by the originators name. That would be a nice addition for this forum as well. I don't mind reading through some old threads but others I would avoid if I knew they had been around a while.
Also: There is no rime or reason to it but I click on some multi page threads I KNOW I have never read and it will advance me to a page further into the thread instead of the first post. Other times I click on a thread I have read and even participated in and dang if it doesn't go to the first post. Then other times I click on a multi page thread and it takes me to the next post right after one I made. The rule for where I end up is very inconsistent. I have my thread display mode set to "Linear, Oldest First".
/ Thread Start Date #2
JD guy, the thread start date and time is under the thread title on the list of posts.
It displays: "Started by (username) on (date) at (time)".
/ Thread Start Date #3
I'm wondering if it's a problem with what you are using... It works and does exactly what you are asking, at least for me! Good luck...
/ Thread Start Date
Shows the date in the thread but not on the thread list. At least not on mine.
/ Thread Start Date #5
This is the way it looks on my list:
Fluorescent to LED
Started by jajiu, 01-04-2018 10:19 AM
Thread Start Date
Started by JD855guy, Today 09:29 AM
FEL/pallet forks as scaffolding
Started by Einthewoods, Today 06:00 AM
It must be what you are using.
/ Thread Start Date #6
Mine shows the same way as mddorange.
JD855guy must be using a different 'skin' to view the site.
/ Thread Start Date #7
When I view threads via the "TODAY'S POSTS" or "NEW POSTS" links, they appear this way for me:
Fluorescent to LED
Thread Start Date
When I go through the "FORUMS" tabs and then select a forum from the list, they appear this way (no date/time listed):
/ Thread Start Date #8
Ok, looks like you have figured it out. Since I always use "New Posts" I have never seen it that way. Good work von-mil.
CAT CB34 (A60462)
CAT CB34 (A60462)
2014 DODGE CHARGER (A62130)
2014 DODGE CHARGER...
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
(2) ROW PLANTER (A62130)
(2) ROW PLANTER...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
(2) ROW PLANTER...
