Tractor rec needed for new land
/ Tractor rec needed for new land #1
kjg26
Buford, GA
2013 Kioti DK55
We just put money down on roughly 54 acres in north east georgia. Our family thinks were are nuts. Once the kids are done with school we will be moving out there. For the time being we will be getting everything back up and running. I am including aerial shots of the property as well as the breakdown of the land. As you can see there is an old house on it that is not uninhabitable at this time. Land is majority pasture, fairly flat. Back portion is fairly overgrown in parts with small saplings, brush, and some bamboo. I would like to get most of it cut back to use it for hay. Anyways i think i will be getting a LS tractor as they have been the most peasant to deal with and seem to have most bang for buck. So....what HP rating? Also what size cutter? Any other suggestions. Wanting to go cab tractor.
Front with house is roughly 19 acres and back is roughly 34. Front has the house.
Screenshot_20180111-173752.pngScreenshot_20180111-173712.png20180111_173340.png20180111_173522.png
/ Tractor rec needed for new land #2
Nice, congrats. 50 hp min tractor.
Was thinking xr4155 hc. Thats hydrostat and cabbed. Has 44 pto horsepower. The shuttle shift only has 47.3. Thinking for the wife the hydro would be easiest. Also looked at a couple brush cutters.
10 ft with hp rating 40 to 120. 2 in cutting capacity.
7 ft with hp rating 40 to 120. 3 in cutting capacity
5 ft with hp rating 40 to 150. 4 in cutting capacity
Also considering the xu series that is 46 to 60 pto hp. It is significantly larger and more money. I dont want to size myself out of smaller jobs.
Do i get a smaller tractor like the Xr series and then buy a massive older tractor for the fields on the long run?
/ Tractor rec needed for new land #4
How many acres of it do you think you will mow on a regular basis? If what you are cutting is very deep that 10 footer will be a little much.
Id like to keep most of it groomed. Maybe grow hay on the back and maybe up front. But for now just trying get everything back in shape.
Most is maybe hip to waste deep. Way in the back its small stocks of bamboo that is well over my head. Figure some hand or grapple work will be needed back there.
I plan to purchase a grapple and cutter with the tractor. Figure i can pick up the rest as i go
/ Tractor rec needed for new land #6
Dig out the bamboo.
/ Tractor rec needed for new land #8
I have a basic 45hp Kubota that I manage 240 acres with. However, not much of mine is pasture. Things to consider: 1) How large a mower you will need. Look at both PTO capacity and the capacity of the rear pistons to lift it if it is a 3pt mower. 2) 4wd vs 2wd. If you can afford it, get 4wd. 3) FEL? The answer is yes. 4) If you will cut hay, what size bails? Large round bails require a heavy tractor with plenty of lift capacity and ballast if only lifting from the FEL. 5) Will you tow it? This is a significant consideration since it is very easy to buy a tractor that is too big for an average 150 or 1500 pick up to tow safely. Consider my situation: I have a truck capable of towing 7000 pounds (03 F150). My tractor is very light compared to other 45hp tractors. But, with the loader, filled rear tires and a box blade it is close to 5000 pounds. Add a 2000 pound trailer and you're at the maximum. If you go to a beefy 55-65 hp tractor with a beefy loader and big implements you might have to step up to a 250/1500 level truck. $$$ 6) Will you use it in the woods and or along woods roads. This can be tough on cabs and big tractors. I use mine on narrow woods roads and quite often in the woods. I would have destroyed a cab the first day I owned the tractor and every day since then. 7) Finally, what is your budget?
/ Tractor rec needed for new land #9
I'm in a similar situation as you. We just purchased 104 acres in Buffalo Tx, with roughly 65 cleared and the rest thick woods. I plan running cattle and mowing most of and cleared on a regular basis to keep the weeds down and hay the smaller field, roughly 20 acres. I've shopped around and looked at most of the big brands of tractors and decided on the same tractor your looking at. I think for the price, warranty and location of an LS dealer has me sold on it. I was at first going to get an 8' mower but have been looking and think since I'm not going to be getting in the woods with this tractor and nothing to thick or cutting brush I can get by with a 10' drag begind or 12' batwing. I getting a cab with hydro for several reasons, first it's Hot in the summer here, second is we plan on having my father in law move up. Being 81 and smoked his whole life he doesn't need be out with all the dust and gunk getting in his lungs. Third the hydro is so dam easy to drive I can even get my wife to drive it with out worry of clutch issues while doing some post hole and loader work. Good luck on the new LS.
No plans to bail hay off the bat. Maybe in the long run. As for a truck already got that covered. 16 ram 2500 diesel. FEL and 4wd are a must. As far as cutter size im thinking as big as possible due the amount of pasture. Is it better to have a smaller cutter that the tractor is sized for or a larger cutter that a tractor just barely meets specs for? Budget is 500 to 600 per month for everything. Cutter and tractor. Wouldnt mind a trailer for towing it.
What model and HP are you looking at? And which cutters?
/ Tractor rec needed for new land #12
Depends on who you ask and what you believe about the stats. Are the stats trumped up marketing figures or are they low ball figures to keep you from breaking things? Hard to say. I'd say keep it well within spec......but that is from someone who regularly maxes out the spec of his own tractor.....so far no major problems.
Not sure how that translates into total cost.
30 to 35k
/ Tractor rec needed for new land #14
I would have recommended a Kubota 6060 but with cab and loader you're looking at $48k. So out of your price range for new. Have you thought about used? As a first time tractor buyer I was afraid to buy used and it was probably wise given the incredible deals Kubota was offering at the time. But now, I'd buy used in a heart beat.
How married are you to the cab idea? It adds a lot of cost. Great for Georgia summers though.
Pretty set on a cab. Not objected to used. Just got to find a good one. Also need look into financing used. 0% on new is hard to argue with.
/ Tractor rec needed for new land #16
Congrats on your new homestead.
What ever model you decide make sure tractor fits you comfortable...let tractor come to your.
/ Tractor rec needed for new land #17
/ Tractor rec needed for new land #18
Agreed. That was what pushed me into buying new too. That and the fact that what I got used was a perfect match for what I needed. In other words, I did not have to compromise to get a new tractor. I could have gotten more tractor if I'd bought used but I didn't need more tractor....and fortunately still don't. You will have to weight that out and see where the scales tilt. My tractor was under $25k but at the time I could not have produced even $15k in cash for a good used one.
/ Tractor rec needed for new land #19
I agree with your assessment of a 50-60 HP tractor being what you need. I don't know about a 10 foot cutter for that size tractor though. My 7 foot will give my LS P7010 all it wants in heavy cutting but for normal pasture clipping to keep down the weeds, you may get by with a 10 foot cutter. I started putting a lawnmower type cutting edge on my bush hog since all I cut is grass and weeds with it, no more saplings to cut. This helps a lot when cutting grass as for as HP requirement.
As for a cab, go for it. They are tougher than most TBN advisors give them credit for. I had run mine thru pine trees that were so thick I couldn't see in from of the tractor because the limbs from the pine tree rows were overlapping. The cab just parted them without a problem. I couldn't have mowed that pine plantation without a cab to keep the limbs off me.
You do have to be careful with overhanging limbs as the roof is the vulnerable portion of a cab. If you have the budget for a cab, for sure go for it, the HVAC is nice not to mention the bug proofing.
/ Tractor rec needed for new land #20
Well, just for a reference, I tackled this with my 45 hp tractor and light duty 6' cutter:
This is the end result:
It took a long time and there was only minimal brush mixed in, but it was not a problem for the tractor or the tiny mower. So as to a 10' mower I think a lot depends on what you are cutting and how wet it is. If the stuff in these pictures had been green and wet it would have been tougher if not impossible. Most cutters have a recommended minimum PTO hp. If you will be doing lots of pasture work you may need two. A 10' pull behind and maybe a 6-7' three point for smaller roads and confined areas.
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
John Deere 18ft. 3 Point Field Cultivator (A65640)
John Deere 18ft. 3...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
