2000lb ceiling hoist/elevator??
/ 2000lb ceiling hoist/elevator?? #2
When you get the pallet of bales up to the loft area, what happens to them then?
/ 2000lb ceiling hoist/elevator?? #3
A mast from a forklift would be my first choice. You can get them pretty easy from scrap yards. Are you unloading the pallet by hand once it gets to the top or are you hoping to set it at the top and move it with a pallet jack? How are you getting the pallet to the lift? How high is it going?
/ 2000lb ceiling hoist/elevator?? #4
Do you have enough room and access to use a forklift? Chances are that you might be able to pick up one that isn't reliable or OSHA compliant enough for daily commercial ops, but fine for personal use. You could luck out and find one for less than a dedicated elevator would cost, and it could be used for other things as well.
/ 2000lb ceiling hoist/elevator?? #5
That sounds like a good idea. You just have to figure out how to anchor it. A 2000# lift forklift usually has a weight of 4-5000 pounds. It's not something you can just anchor to a wall or floor. It needs significant counterweight, or rollers on a beam on the opposite wall.
For that matter, I'd bet a used forklift would be almost as cheap as building a dedicated lift from scratch, and be more versatile around the farm.
/ 2000lb ceiling hoist/elevator?? #6
That would be my first choice but I made my previous comment on building a lift. The biggest problem with forklifts is they don’t go off road very good at best. Forklifts capable of going off road around nearly as compact and more expensive.
/ 2000lb ceiling hoist/elevator?? #8
That's true. They do get stuck in slight mud or snow very easily. But even at that price, you could pour a concrete pad and park it there permanently and use it as an elevator.
/ 2000lb ceiling hoist/elevator?? #9
I’ve got cheaper forklifts than that. I’ve got 2 that are operational for less than $2000. One of mine has tiny wheels like that one and it won’t go off a concrete or asphalt at all. The other one has bigger wheels but is still a warehouse forklift. It’ll go on gravel and firm dirt. As heavy as that are anything that even resembles mud is out of the question. I wouldn’t be surprised if the tiny wheeled one could be gotten stuck in hot asphalt.
/ 2000lb ceiling hoist/elevator?? #10
A pneumatic tired one like mine does pretty good in packed dirt and gravel, even though it it stuck in the lawn in the avatar pic. Hadn't dried out enough when I tried moving a trailer. Chances are that an area can be prepared well enough to use it all year for hay moving. Mine would be a lot more capable with new drivers on it, they're pretty smooth. One of the reasons it was so cheap.
/ 2000lb ceiling hoist/elevator?? #11
Have you thought about the lifts used at docks to cradle boats and lift them out of the water? Most use electric motor and wind cable on pipes suspended in ceiling.
/ 2000lb ceiling hoist/elevator?? #12
How big is the area you have to work with? Bottom level top level? Is there exterior acess to the loft or how is it set up? What is there to fix a hoist to?
/ 2000lb ceiling hoist/elevator?? #13
Don't forget to factor in the weight of the car or pallet you plan to put the hay on. Something 6x8 that will hold that many hay bales is going to have a fair amount of weight JUST in it.
I use a 120vAC "Strong Arm" winch (w/out clutch for overhead lifting) on my wood elevator. They make a model that is rated up to 4000lbs Dutton-Lainson Company - Since 1886. This is often used to lift smaller boats out of the water for winter storage.
I use the SA9000 model to lift a 2x2x4 car of wood from the basement to the ground floor level. I went thru several lighter weight winches over the years before I switched to this one. So far, it's done a pretty good job.
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
OVERHEAD PROJECTOR, HP PRINTER, (2) MONITORS (A64276)
OVERHEAD...
SANY SY155U EXCAVATOR (A63276)
SANY SY155U...
