So much for leaving it until after Christmas, I can't seem to rest while this machine is still occupying my workshop.
I tackled the power steering leaks again today. New copper washers, stacked to achieve the necessary thickness, solved the leaking pipe banjos but once that was sealed, as soon as the steering hit lock, oil sprayed out of the side cover gasket.
I got to thinking that perhaps the pressure relief valve in the pump was stuck and over-pressurising the system; removed the pump, stripped the valve and fitted a new O-ring but it all seemed pretty good. I pulled off the side cover and discovered that the gasket supplied in the Bareco overhaul kit was poorly made, one hole was out of position and made a path for the oil to leak out under pressure. The photo shows where the punched hole is off line with where the bolt has gone, and the incorrectly placed hole is very close to the edge of where the cover has compressed the gasket.
I had some gasket paper in the appropriate thickness so made a new gasket, coated it with quality gasket spray and re-installed the cover. No more leak.
Getting rid of all the oil leaks on this machine was one of the major objectives in doing the overhaul- it has leaked out of virtually every seal and gasket for as long as I have owned it. I seem to be getting there, although there is a fuel drip from the injector return line and possibly from the injector pump also- I'm not completely sure if the pump return line leak is dripping onto the pump or if the pump itself has a leak. I will have to get to that in due course, however the next mission will be to sort out this wiring loom.
