thermostart
/ thermostart #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
first time I have used this function since I've had the tractor.
It was 17 deg here yesterday. Turned to TS.Then, turned over about 6 times and fired right up. I couldn't believe it:cool2:
Even though I now own a Kubota, I still rely on the Yanmar for a few chores :thumbsup:
/ thermostart #2
Isn't that thermostart neat? This has been a mild winter so far in the high Rockies but thermostart works fine in warm weather too. And it's so simple. The one on our YM165d is the old type that doesn't even connect to the diesel fuel return line. For fuel it just has a one oz. plastic cup with a cap. Apparently it is designed to be manually filled every few years. Everytime I use it I think about adding thermostart to our other diesels. Someone should offer a kit. No reason at all why it wouldn't be an advantage for any other diesel. All it takes is one tapped hole in the intake manifold and one wire to a switch.
rScotty
/ thermostart
Mine was designed to be manually filled also. A few yrs ago, I found a filter with a Y and installed in in the return fuel line. Now, it stays fill
/ thermostart #5
I have the Thermo Start just no cup. In Ga. In the last 10yrs. I rarely ever use the TS.. A handful of times. Never had the cup which I didn't realise until after I bought it and even had to wire it to the Ign. switch. Was really surprised to find everything was in working order with just no way to get fuel to it. But when I do need to use it I just setup a quick and easy way to get fuel to it. And when I'm finished with it I can easily remove it. Just another simple and easy way Yanmar gets heat to the cylinders. I used 2 manufactures of tractors on my lot clearing it and the yanmar was far superior. The Kub B-2800 was a problem from the day it was dropped off. The biggest PITA was when you would turn the steering wheel with PS., Hyd. fluid would squirt out at the Steering column and right in you Lap. Yup!! and it just was at the Dealer for Serv.. When we talked with them they told us it required a split!!!!
Buying it was definite a no go but I was able to come up with a Getto rig. that easily took care of the problem so I was able to use the BH. and take care of a few things. I believe the owner was happy about it and as far as I know left it rigged.. The JD that I've used and kept up with hasn't had the first problem besides Maint. in over 10yrs.:thumbsup:. I actually have a old photo I posted on here yrs. ago of what I did to use the TS.. And it still works great....
And
frugalangler basicly it uses a elemnt to ignite a small amount of fuel to ignite it creating heat for a cold start.
/ thermostart #7
Most ant info. your need on a Yanmar just go to Hoyes sight at the top of the page.
/ thermostart #10
Well said. That's the most concise description ever.
I would have taken a paragraph to say the same thing.
I'm guilty of a paragraph and could have been two or three even. but I at least tried to keep it separate for frugalangler and simple. And only misspelled one word. Imagine that!!!
/ thermostart #11
and my simple mind appreciates - TS is an interesting concept, albeit primitive but it works!.
/ thermostart #12
I have a Yanmar 336. It is a bit hard to start in the cold even when one turns the key counterclockwise to preheat the fuel. Is the thermostart available for my tractor? It does have a plug to heat the block but I have no electricity at the farm to use it. I have a battery pack that might help but the thermostart would be much faster.
/ thermostart #13
If you don't have a thermostart module in the intake manifold (looks like a spark plug) then turning the key counterclockwise does nothing. If you find a blind plug there, installing a thermostart module and its related fuel reservoir is simple. Buy the parts from Hoye. (See post #6 above).
Or if the components are there but the manifold doesn't feel warm after turning the key left, first verify that electricity is getting to the module when the key is turned. More likely you need a replacement module. They aren't expensive. Tractor Supply, Ebay, or Hoye.
An old post discussing the thermostart with photos (recognize one of the photos? :)) and describing its use, testing etc.
http://www.tractorbynet.com/forums/yanmar/159725-thermostart-photos-ts-flame.html#post1831717
Thermostart module: I think there are only two versions, screw terminal and slip-on connector, easily interchangeable.
68476d1169070962-can-i-add-thermostat-glow-dscn5123thermostart-perkinsbox-jpg
/ thermostart #14
Yes that is me also back in the UTDA days. I was told that it would be taken care of.............
