$100 Hydraulic Top Link
/ $100 Hydraulic Top Link #1
huffman102833
Houston, TX
New Holland Boomer 41
I'm looking to add a hydraulic top link and noticed that ASC sells one for $100.00. Has anyone had experience with this unit? Seems like it's quite a bit less than any others I've found but I don't want to end up with something that is going to leak.
Here's a link: Hydraulic Top Link-Tractor3 point| Agri Supply 9599
I did a little more reading and it looks like they are made by Agmate. There's also a 3" version available for $140. I attached the product doc as well.
Has anyone had experience with these units?
  • Grizzyly_Cylinder.pdf
/ $100 Hydraulic Top Link #3
I did a little more reading and it looks like they are made by "Grizzly". There's also a 3" version available for $140. I attached the product doc as well.
Man that’s a good find. Might pick up a cat 2 one. 8” of stroke should be good for me but I’ll measure my pins before I commit
Brett
The ASC pic looks like there isn't much clearance from the base to the eye but the pic in the brochure shows it with an extension. I may call to make sure.
I suppose another option would be a knuckle end but I can't seem to find a source in the US.
/ $100 Hydraulic Top Link #5
I just built one (for a minimum savings) but got a much longer stroke. The knuckle is simple to build if you have the right stuff on hand.
/ $100 Hydraulic Top Link #6
I just installed one yesterday. It seems to be pretty good quality for the money. I haven't used it yet other than cycling it in and out a bit to test for leaks and purge air out the system. It moved my 750 lb snowblower without any issues or leaks. I don't have any clearance issues with it in the stock configuration. The top link I received was the one show on the the webpage not the one in the brochure.
/ $100 Hydraulic Top Link #7
You guys need to check to see what working length you actually need if you are concerned about actually using your implements to their fullest capacity, and if you are concerned about being able to use all of your pin locations on the tractor.
Typically I would supply a boomer with a 17"-23" working length. This gets you about 3" of travel in each direction with the implement in the front-back level position. This also gets you the ability to use all 3 pin locations.
The JD 5000E models take a 19 1/4"- 27 1/4". Same sort of scenario although this gets you just a bit more retraction than extension.
If getting the maximum working capability is not important, than these generic top links are a GREAT deal.
I believe that in general, you will find these particular units a bit long in the fully retracted position.
Good luck to you all. :thumbsup:
/ $100 Hydraulic Top Link #8
Nice build Eric!!!! As my Dad would say "Just like the kind you buy". :)
/ $100 Hydraulic Top Link #9
Well stated Brian!!!
And if you can't find the data you are looking for then attach an implement such as a BB or Rear Blade and adjust your manual top link to the ranges you expect with the top link and take some measurements.
/ $100 Hydraulic Top Link #10
I think you build top notch top links and value your opinion. However, for $170 to my door plus hoses and have it going in less than a week it’s very tempting. How many weeks lead time are you at now? I would think you’d get slammed this time of year. Where are you on price for one turn key for my 5100e? Only use it for my box blade
Brett
Thank you all for the input. It's great to have a place to receive objective feedback from folks that have experience. I took some measurements and it looks like the 20"-28" is well within my required operating range.
I'm going to go ahead and order one and I'll report back once I get it installed. Thanks again for all the advise.
Dustin
/ $100 Hydraulic Top Link #12
We appreciate the follow up Dustin!!!
/ $100 Hydraulic Top Link #13
From their doc
ASAE is the American Society of Agricultral Engineers.
Might just show the level of their quality control.
/ $100 Hydraulic Top Link #14
I was going to get one of those this summer, but with the exchange rate, and having to pick it up stateside, I got one custom made by the company that makes cylinders for Wallenstein. I got it made bigger and to my exact length I wanted. It was surprisingly cheap and done in a couple of days.
I believe it was $180.00 CDN. I picked it up.
/ $100 Hydraulic Top Link #15
I think you build top notch top links and value your opinion. However, for $170 to my door plus hoses and have it going in less than a week it痴 very tempting. How many weeks lead time are you at now? I would think you壇 get slammed this time of year. Where are you on price for one turn key for my 5100e? Only use it for my box blade
Brett
The whole point of my post was that these generic top links typically are not the ideal working length for these poster's tractors. I always try to get at a minimum of 3" of stroke in each direction. Others do not, in fact I have seen where with the top link fully retracted a box blade would only be level, zero front tilt ability. Is that what you want and have to deal with? A box blade sure doesn't work very well set up like that if you are trying to make a cut.
If you get one that is 22" collapsed, I doubt that you will be very happy with it and the performance that you will get from it. I hope I'm wrong. Plus you will have to grind the tractor end down from 2" to 1 3/4". Not a big deal, but it will need to get done just to get it installed on your tractor, and then it is no longer returnable if you are not satisfied with the working length.
As far as my lead times, I started 2017 at 10-12 weeks. I'm currently running at 17-19 weeks, at last count had over 112 orders to work on. I can't give you a total cost, I have no idea where you live other than Texas. So it is impossible for me to get you an accurate delivery cost, $50-$60?
But a 3" top link with the correct width tractor end (1 3/4" wide) and LARGE cat 2 ends at that, (There are many different actual sizes of cat 2 ball swivel ends on the market.) hose kit and flow restrictors would be $495 + shipping costs.
You typically get what you pay for, if-when the low $$$ stuff works out, then the consumer comes out ahead, :thumbsup: if not then not so much. :(
I hope that it works out for all of you. ;)
/ $100 Hydraulic Top Link #16
Brian, I say this with love, there's no way I'd wait 4 months for a hydraulic cylinder!!!! :confused2:
I'm glad your business is continuing to grow!!!! It's went wayyyy beyond what I thought it would. That's an indicator of two things, quality and availability. :thumbsup:
/ $100 Hydraulic Top Link #17
I agree about the lead times, they suck. Fortunately for me, my customers are not like you and ARE willing to wait. Every customer knows the lead times when I quote them, no surprises. A lot of people want me to hire help, problem is that entails a whole set of problems in itself that at this point in my life I have chosen to not deal with those issues.
I provide an excellent product at a fair price and build what people need, not "here it is, hope it works for you" type of thing. The other plus for my customers is that I build pretty much every top link from a cat 0 12hp garden tractor to cat 4 600HP Articulated AG machine. No one and I mean no one else provides the range of these products that I do.
For a lot of this stuff, it simply is not mass produced, so you can build it yourself, get a local shop to do it or have me do it. The advantage for me, is I'm set up for this and typically have all the required parts in stock. :thumbsup:
/ $100 Hydraulic Top Link #18
An old deceased friend who ran a service station back in the 50s said the day he hired someone is the day he stopped making money. Can that be any more true today?
/ $100 Hydraulic Top Link #19
Again, I say this with love. If this wait time continues long enough your competition will show up.
/ $100 Hydraulic Top Link #20
[snip]
Brian, to say nothing of (1) your knowledge of particular tractor brand and model issues (2) your personal service before and after the sale, and (3) your willingness to share your expertise with folks who may not even have ordered from you. I'm a case in point. You helped me with the right flow restrictors and couplers even though I'd sourced my top and side links from two different vendors. I'm not surprised that your business has grown so much.
2010 Unverferth 1225 Rolling Harrow (A63116)
2010 Unverferth...
2015 John Deere 3046R Compact Utility Tractor (A63116)
2015 John Deere...
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2022 Timpte 1424 All-Aluminum Equipment Trailer (A63118)
2022 Timpte 1424...
Case Titan 3530 (A63118)
Case Titan 3530...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
