Plow size
/ Plow size #21
The rear offset blade
/ Plow size
So I gave some more thought to bushings & Various sizes and came up with this. The green tape is just marking the location of the floating 3 point mounts that I need to drill thru and pin to keep plow from sliding on bar (left to right ). Tractor supply came thru ...collar bushings with Allen set screws fit perfect inside 3 pt 1-1/8” bore , then grade 8 washers, and a couple sleeve bushings with more grade 8 washes to keep pin stable ... more pics tomorrow ... CA693B49-133B-4B09-8F92-ECCB72A1C388.jpeg5002DDCA-50F3-43C3-8709-BF71A764797B.jpeg
/ Plow size #23
So I gave some more thought to bushings & Various sizes and came up with this. The green tape is just marking the location of the floating 3 point mounts that I need to drill thru and pin to keep plow from sliding on bar (left to right ). Tractor supply came thru ...collar bushings with Allen set screws fit perfect inside 3 pt 1-1/8” bore , then grade 8 washers, and a couple sleeve bushings with more grade 8 washes to keep pin stable ... more pics tomorrow ... View attachment 533958View attachment 533959
Your mount looks great, but can you show another photo a little further away as well. I’d like to get a bigger view.
/ Plow size
55AAAA08-50DF-40F0-ADF9-846A7E2A0710.jpeg9B43AED8-C75B-489A-B849-9D867893940F.jpegEB76D04C-93BB-4F78-80FD-9C1C947696F8.jpeg
More pics of attachment configuration...
/ Plow size #25
Did the Titan 3 point adaptor quick attach plate fit the plow that perfectly stock, or did you custom order it to fit the plow A frame?
/ Plow size
The titan Qa plate has adjustable lower 3 point brackets that slide left to right... I have to drill & pin with hitch pins to keep it centered... they don’t offer any specific Qa plate to match a plow that I am aware of.... becomes a matter of how mechanically inclined you are to see the way to adapt / configure something to something else
/ Plow size #27
Apparently that's what Drewmon did to his QA. Drilled holes and installed hitch pins to keep it centered. Wish I'd have seen that hitch before. It would have saved me a lot of welding and fab time building mine.
/ Plow size #28
Me too, but I paid $125 for the QA plate and welded the mounts on for free. So I saved $150. I'll take those savings and use the money for something else for the tractor!
/ Plow size
Here it is all mounted... 97BE4893-F466-4095-AB50-CF3240579B6A.jpeg0DDE8D0C-3019-4CEA-9E90-098BB15CEE7B.jpegC9C0D144-0137-4EEA-817A-F03925B53411.jpeg8632B63A-8076-4C35-AD45-BF34E7DA86FF.jpegC9F48A57-2C65-4236-BDE6-2F6689621A27.jpeg
/ Plow size #30
Looks great! Just in time for Thursday's snowstorm. Where are you in CT? The NW hills are getting 3-4 inches, and the NE side is getting 8-12 inches.
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
75 TON IRON WORKER (A64280)
75 TON IRON WORKER...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
Caterpillar D6M Dozer Service and Parts Manuals (A63117)
Caterpillar D6M...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
