Plow size
/ Plow size #21
The rear offset blade
/ Plow size
So I gave some more thought to bushings & Various sizes and came up with this. The green tape is just marking the location of the floating 3 point mounts that I need to drill thru and pin to keep plow from sliding on bar (left to right ). Tractor supply came thru ...collar bushings with Allen set screws fit perfect inside 3 pt 1-1/8” bore , then grade 8 washers, and a couple sleeve bushings with more grade 8 washes to keep pin stable ... more pics tomorrow ... CA693B49-133B-4B09-8F92-ECCB72A1C388.jpeg5002DDCA-50F3-43C3-8709-BF71A764797B.jpeg
/ Plow size #23
So I gave some more thought to bushings & Various sizes and came up with this. The green tape is just marking the location of the floating 3 point mounts that I need to drill thru and pin to keep plow from sliding on bar (left to right ). Tractor supply came thru ...collar bushings with Allen set screws fit perfect inside 3 pt 1-1/8” bore , then grade 8 washers, and a couple sleeve bushings with more grade 8 washes to keep pin stable ... more pics tomorrow ... View attachment 533958View attachment 533959
Your mount looks great, but can you show another photo a little further away as well. I’d like to get a bigger view.
/ Plow size
55AAAA08-50DF-40F0-ADF9-846A7E2A0710.jpeg9B43AED8-C75B-489A-B849-9D867893940F.jpegEB76D04C-93BB-4F78-80FD-9C1C947696F8.jpeg
More pics of attachment configuration...
/ Plow size #25
Did the Titan 3 point adaptor quick attach plate fit the plow that perfectly stock, or did you custom order it to fit the plow A frame?
/ Plow size
The titan Qa plate has adjustable lower 3 point brackets that slide left to right... I have to drill & pin with hitch pins to keep it centered... they don’t offer any specific Qa plate to match a plow that I am aware of.... becomes a matter of how mechanically inclined you are to see the way to adapt / configure something to something else
/ Plow size #27
Apparently that's what Drewmon did to his QA. Drilled holes and installed hitch pins to keep it centered. Wish I'd have seen that hitch before. It would have saved me a lot of welding and fab time building mine.
/ Plow size #28
Me too, but I paid $125 for the QA plate and welded the mounts on for free. So I saved $150. I'll take those savings and use the money for something else for the tractor!
/ Plow size
Here it is all mounted... 97BE4893-F466-4095-AB50-CF3240579B6A.jpeg0DDE8D0C-3019-4CEA-9E90-098BB15CEE7B.jpegC9C0D144-0137-4EEA-817A-F03925B53411.jpeg8632B63A-8076-4C35-AD45-BF34E7DA86FF.jpegC9F48A57-2C65-4236-BDE6-2F6689621A27.jpeg
/ Plow size #30
Looks great! Just in time for Thursday's snowstorm. Where are you in CT? The NW hills are getting 3-4 inches, and the NE side is getting 8-12 inches.
211299 (A62131)
211299 (A62131)
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
OXBO CP100 - 1R SWEET CORN HARVESTER (A63291)
OXBO CP100 - 1R...
2022 EZ-GO ELITE...
2019 Chevrolet...
