Hydraulic winch
/ Hydraulic winch #1
ptsg
Super Member
Portugal
Branson F36Rn - Agria 8900D
Most of my work is done on some steep hills with some hidden holes and such, I find my self on situations that requires a lot of diff lock work and I've been getting away with it but I want to have another place in case the diff lock doesn't make it.
So I decided to build a hydraulic winch for my Branson F36Rn tractor since I had most of the stuff anyway. Just need to buy the cable and the hook.
Ended up being a 6000 lbs winch with a weight of 130 lbs that will work nice with the 224 lbs weights that came with the tractor. It was still a bit light with the brush hog on. I won't use this as a logging winch. This is purely for get tractor out of a stuck situation. It has about 160 feet of steel rope and free spool option with a brake so it doesn't unwind like crazy. The drum is supported by 2 bearing on each side.
I also made a bumper so it pushes the brush away from the hood of the tractor preventing from scratching the paint which also made the perfect spot for a couple of small LED light bars.
Everything works awesome, I'm really happy with it.
HPIM5260.JPGHPIM5262.JPGHPIM5264.JPGIMG_20171109_181521.jpgIMG_5695.JPGIMG_5697.JPGIMG_5700.JPGIMG_5701.JPGIMG_5724.JPGIMG_5725.JPG
/ Hydraulic winch #2
Nice work, looks like u spent same time planning it out:thumbsup:
/ Hydraulic winch #3
Very nice indeed !! Looks like it belongs there - A perfect place for a hydraulic winch.
gg
/ Hydraulic winch #6
Power Trac offers two Hydraulic winch models suitable for low GPM output for those without a nice base unit to begin a build. Prices range from $900 to $1300. The power trac mounting plate is unique to their system but easily modified to a front or rear application. CAUTION: most sub-100 hp tractors do Not enjoy a full frame chassis, so care must be taken to not overload the pull on front bumper or you may end up with a TWO piece tractor. As I recall, winch rating is in the ton to ton and one-half rating. There is little comparison between a DC motor winch and hydraulic power, when performance is evaluated.
/ Hydraulic winch
Thank you all :thumbsup:
I wanted something compact that would fit nice on the front of the tractor.
I only build this front winch because the tractor comes with a middle ROPS installed, therefore there is a 4" by 1/2" flat bar all the way from the front weights to the gearbox. This tractor is really well built with really heavy duty castings. I think it spreads all the forces trough the whole tractor instead of just the engine block which is not desirable.
I had take a look on buying the winch instead of making it, but it is a lot of money. Even for the electric ones and since I had most of the stuff, I just decide make it. That Power Trac unit looks really neat also.
/ Hydraulic winch #8
Vey nice, quite compact, very efficient & professional. Of course, you know - now that you have that nice winch, you will probably never get stuck and need it - ha,ha.
/ Hydraulic winch
Thanks! Yes you got that right! :laughing:
/ Hydraulic winch #10
The additional reinforcement you NOW describe was omitted from original post. I am NOT an engineer. My comment was a FYI to others seeking to duplicate your build.
/ Hydraulic winch #11
That is a very impressive build.
/ Hydraulic winch #12
Nice Work!!
I wish I had clearance for something like that on my L6060. I'm always getting stuck when plowing. There isn't much clearance between the frame and FEL when lowered so it's tough to find a spot to put a winch. I thought about making a 3 pt winch mount but I usually have the blower or sand spreader on the back in winter.
I considered making an easily removable winch bracket that would fit between the FEL arms on the cross tube. That way I could power the hydraulic winch via the 3rd function valve and install it only when needed. I'm afraid pulling too hard with it could damage the FEL though.
/ Hydraulic winch
Thanks!
Yeah mounting on the FEL cross tube might work however be very careful and never ever pull it's side ways. It might bend the FEL arms. Have you considered a electric or small hydraulic winch? I mean, mine is way overbuilt since it's homemade and it has way more power than I need.
/ Hydraulic winch #14
Bdhsh26
First the L 6060 is an impressive tractor. Curious how you get stuck plowing? Could you elaborate upon the conditions/circumstances. Noted in an earlier post, when mounting a winch at the front bumper, on a tractor without a full chasis frame, serious potertial exists to stress motor attachment points. A winch attached to SSQA plate, pulling directly in line with the tractor position appears more prudent than a cross lateral stress position. Additionally, your reluctance in attaching to the loader cross tube seems wise. Front loader stress points are designed to equally divide between both loader arms, not a single point on the tube. Certainly the rating of the winch, coupled with the resistane of the object being pulled is the major consideration. What implement is attached to the loader when plowing?
C
/ Hydraulic winch #15
Thanks!
The one you built would definitely be overkill for my purposes. Compact tractor electrical systems aren't really designed for heavy loads and I'd be concerned about a dead battery with an electric winch. I was considering a lighter hyd. unit such as:
Warn Industries - Tow Truck & Industrial Hydraulic Winches: Series 6
It only weighs 40 lbs. and would be easily removable. I would mount the fairlead on the frame below the winch to avoid any side load on the FEL arms.
/ Hydraulic winch #16
Bdhsh26
C
I have a LandPride 1596 SSQA plow on the FEL of the L6060. I plow 1.25 miles of very steep private road with a high crown and deep drainage ditches on either side. Even with chains, I occasionally get stuck. When conditions are really bad, I'll leave the BH92 hoe on to crab my way out of a jam. Unfortunately, I can't use the snow blower or cinder spreader with the hoe on. The road is tree lined so it would be easy to pull myself out with a winch.
If I were to mount the winch on the FEL cross tube, I would bolt the fairlead to the tractor frame. That way, the winch would only pull upward, eliminating any side load on the FEL arms.
This is just one idea I've been working on and may never build it.
/ Hydraulic winch #17
Nice Work!!
I mounted a hydraulic 8000lb winch in my loader. It works great. I use it more than you can imagine. Anytime you pick something with a chain on the loader it either too short or long. Having that winchline up front is great. When moving brush I lay it out on the ground and make a pile, bring the line back to the tractor, suck it up and lift you get it all. Also it it is piled already I take some line over the pile, roll the pile over the line, hook the end and winch it up. I have pulled many others out of situations that were buried. putting the loader in the ground for a deadman and putting a block on the stuck unit to double the power, I have never failed to pull them out. Only once have I had to use it for pulling myself out. I was on a side hill mowing and slid into the fence. I tied to a tree, lifted the loader up and pulled till it started to lift the downhill side and slowly rolled away like a pendulum off the tree, no damage to the fence. I mounted mine below the crossbar and above the bucket so the line wouldn't burn on the top of the bucket. I did put a clevis on the bucket to attach a pulley to be able to pull sideways just in case.
I also have a hyd winch for the rear. I built a frame and for the top link I made a boom that rides on top the winch and sticks out a couple feet. I can hang a pulley or tongs on it. When lowered it goes close to the ground and lifted it is several ft high as it pivots off the top of the frame.
For my smaller 2610 I put a 10,000lb electric on it as I had one laying in the shop. On both the hyd and electric I put a 2 inch receiver. Is very handy for moving trailers and for winching things on the trailer. When the tractor is not in use with mowers, tillers and such I put the winch on. Keeps the arms off the tires.
There is a picture although a bit dark under rdbrumfield 12 12 2002. you can make a search for it if you like.
/ Hydraulic winch #18
I'm glad someone has tried this successfully. I'll search for your pic. I'm going to have to seriously consider a winch again since I've already been stuck once this winter season. I managed to pull myself out with a rope and pulley. I hooked the pulley to the tractor frame below the FEL bucket, tied one end of the rope around the bucket, ran it through the pulley and tied it off to a tree. I was able to pull myself out 6 feet at a time by raising the bucket, lowering it, taking up the slack and raising it again. Slow and a lot of work but it did the trick.
/ Hydraulic winch #19
If there is room to mount a winch to your tractor using the loader frame I would certainly think about it, or as has been mentioned a 2" receiver mounted on the front and possibly on the rear of the blower and then either a hydraulic or electric winch. When pulling from the front if the front wheels are turned in the direction of pull I would not worry about the strain on the tractor it's no more then you would have if someone was pulling you out. It's not like you are bellied out in mud with an implement buried behind you, with the tractor helping to move you will not be pulling that hard. As far as an electric winch the larger ones are going to be pulling upwards to 400 amps and more no alternator is going to cover that, but if your battery is good and your tractor is running you will get a good pull off a winch before the battery gets to low to pull then while the winch motor is cooling the battery is getting charged for another pull.
/ Hydraulic winch
Just watched a video of a local Kubota dealer selling a brand new M6060 with front loader and an electric winch mounted like I did. I'll try to post it later in this thread.
