B3300 Front axle oil
   / B3300 Front axle oil #1
kkcomp
Jacksonville, FL
Kubota B3300SU
I am probably going to go duh but how do you add oil to a B3300 front axle? I can easily find the vent pipe and the big yellow cap but is the cap a twist off or a pop out? I have turned it many times but it just turns. If it is threaded I don
t want to just yank it out.
   / B3300 Front axle oil #2
It's just a push in plug. I use a pair of slip joint pliers to get a better grip on it, then twist as I pull up.
Joe
Joe
Got a chance to try last night. Had to eventually get a screwdriver under it and pry it out. Once out I found that some fine sand was around the plug making it stick. Cleaned it off with a bit of 600 grit and put petroleum jelly on it. Still a good fit but can remove it by hand now. Thanks for the reply.
   / B3300 Front axle oil #4
I've heard that petroleum jelly can have a bad affect on rubber components. I would use plumber's grease. It used on O-rings and similar type components for a better seal in plumbing. And if it's safe for drinking water, you know it's non-toxic.
I have been using it for decades and never had a problem. BTW nice picture.
   / B3300 Front axle oil #6
Same here. For over 40 years I have been using vaseline when installing radiator and heater hoses on everything from cars to highway rigs to bulldozers and never have had a problem. It makes the hoses much easier to remove when required. Just my experience.
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
