Friend is getting a D8!
/ Friend is getting a D8! #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
A friend of mine who has property across the road from my country place is getting a Caterpillar D8 to clear some land for pasture. He has indicated that I could use it (or have him use it) to clear some small areas on my property as well. It is an older one. His uncle, who is my brother-in-law and who owns the cattle farm next to my place, showed me a picture of it. It is an older model without the raised drive sprocket, which means it is probably a D8K from late 70's early 80's. It looks gigantic.
Around here this type of equipment often becomes "community property" with whoever uses it helping with repair and maintenance costs. Don't ask me why or how it works but it does.
Anyway, I'm just wondering a few things. How much fuel do these things use per hour? Can an average tractor owner operate one to do simple tasks? From the videos I've seen the controls look very basic but I'm sure that actual effective operation requires experience. If I were to operate it, what are common hazards and things to watch out for. It has the full ROPS but not a cab. The jobs I need doing would be clearing and smoothing a few acres with small pines and cedars (20-30 feet tall but thin). What types of goof ups would damage the machine?
It does not have a ripper but he is planning on adding one....I'm guessing a three shank.
/ Friend is getting a D8! #2
If you are a proficient tractor operator with good "common sense" regarding heavy equipment you can operate it. To be proficient with it is another story, and takes years of experience.
/ Friend is getting a D8! #3
I cleared 160 acres of thick jack pine in the early 1960's with one and the boss spent 10 mins. with me told me how he wanted it piled and not to back and get myself killed with a tree coming in from behind.
/ Friend is getting a D8! #5
Don't over think it as they say,take your time for couple hours and get the feel,most all don't bog down the motor....watch out for bee hives.
/ Friend is getting a D8! #6
The biggest obstacle to effectively using a dozer is getting up the tree and roots without getting 10 tons of dirt at the same time. Even a good operator with get some dirt. You need a root rake on the blade for piling after you push everything down, otherwise it is pretty hard to push up the timber without a lot of dirt going with it.
Collecting all that dirt leaves some holes that have to be refilled after burning the bush pile so a second use of the dozer might be necessary.
/ Friend is getting a D8! #7
I ran a Cat D6 while in Alaska, for one day. I had/have absolutely no experience on a dozer. Everything was peachy keen - I drove it around for half an hour learning the controls - until I actually had to clear land. I was able with very little difficulty to make one large mess of dirt, brush and trees. The only thing I can say to my credit - I didn't get the dozer stuck. Clearing land with a dozer, like many other activities, is an acquired art form.
If the neighbor has experience - why not have him come over and do the work.
/ Friend is getting a D8! #8
Be very careful around wet areas, you get stuck with a D8 you are not going to be able to pull it out with anything much smaller than it. I got involved with try to extract a D7 from a sidehill swampy patch when I was working for a big timber company in 1977. The operator had many years of experience, he was pioneering a new road and got stuck in an alder grove. The alder trees were 12"-18". We probably cut a couple of cords to throw under the tracks to no avail. The rear drum would simply pull the alders out of the ground like a weed, at one point we tried going around a clump of 7-8 alders - it sucked them all together them pulled them from the ground. We finally found a solid old growth Doug fir stump about 8' in diameter to hook on to. The 1.5" steel cable was sparking it was so tight but the stump held and the Dozer came free. (Yes we were standing way back when this was happening).
Keep in mind a D7 is considerably smaller than a D8.
/ Friend is getting a D8! #9
It's really not the machine one wants, to learn how to run a dozer. There are many things and tricks that save both fuel and wear and tear. And yes, they are thirsty. And incredibly expensive to repair. If I owned one, only the most experienced people would ever be allowed to touch it. Probably if I was smart, I wouldn't even let myself operate it. A person that allows anyone to run his D8 must be a fool or very rich.
/ Friend is getting a D8! #10
I learned to run a D9H back in the early 80s. The clutches are the weakest link in the drive system. Do not load up a full dozer blade and use the clutches to turn the machine with. Straight pushes until you learn how to turn using the side to side tilt on the blade.
/ Friend is getting a D8! #11
One may be able to ‘drive’ but not ‘operate’ it, so to speak.
Fortunately the small area I need to have cleared is dry and fairly flat. Trees are small and mostly pines which should not take a lot of dirt with the roots ball.
I do not know why he bought such a large dozer other than the fact that he has 40+ acres to clear and that it was available locally and delivery was included in the price. He will likely sell it after a few years. Most repairs would be done by my B-I-L. He has large shop for his farm equipment. He has worked on articulated loaders, smaller dozers and he has rebuilt a WWII halftrack. So there is some experience there but none with anything this large.
None of the three of us has any experience with equipment this large. The fellow who bought it is a young man. He operates heavy lift ocean going ships, but no experience with dozers. He does have plenty of time to learn it and plenty of space to learn it in. As mentioned, my B-I-L has some experience with heavy equipment like the articulated loader (now defunct), bob cat, large ag tractors etc, but again, no large dozer experience.
I will assure you that neither of these two guys are fools or anything close to it. I'm not sure I'd say either of them are rich, but both are quite shrewd with their money. If they let me drive it, well, then maybe that would be bad judgement. But I'm no fool either and if they don't think I should run it and if the collective wisdom here is that I do not run it, then I will decline even if they offer to let me. However, I may ask if they'll let me just putter around for a few minutes out in the open just to play with it like a kid on a toy. ;-)
/ Friend is getting a D8! #13
If you do drive it be careful. You can very easily imagine you are Rommel, lead your tank corps on the last stand to retake Tobruk.
/ Friend is getting a D8! #14
Common sense goes a long way, but if you have never been around this type of equipment, learning things can get expensive and dangerous. Go slow, be careful, pay attention and as my Pa told me on TD14, don't ride the brakes or clutches.
Well, one thing is for sure. That thing is going to be parked right across the road from my house and the guy who owns it is usually away from home three months at a time so I'll probably climb up on it every few months and pull the levers and make engine noises for a few minutes. :cool:
Another question, from the videos I've seen it looks like there are two levers for steering but it also looks like there are two brake pedals. Do you use these together? Also, where is the gas pedal? Or is it the longer lever to the right? Finally, it looks like this particular one will have 'direct drive' rather than 'power shift'. Do you have to stop to shift?
/ Friend is getting a D8! #18
Steering clutches used with the breaks . Long lever clutch and you stop to change gears but for clearing land you stay in 1st or at the most 2nd.
/ Friend is getting a D8! #19
I believe on Gold Rush, some hired hand didn't notice the warning light on the dozer and fried the tranny. I think that was an 8 or 9. 10Gs probably wouldn't touch that.
/ Friend is getting a D8! #20
A couple of things, when mistakes are made, they are BIG mistakes. If you think oh well, I can just fix that with my L4400. A mistake that takes 30 seconds to create on that 8 may take you a FULL day to fix with your tractor.
Good luck.
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
