155D 300hr service.
/ 155D 300hr service. #1
chevy791979
white heath IL
155d yanmar
So last night I decided to run the valves and change oils and such. The valves were around 12-14 thousandths should be .008. No big deal but at only 300 hrs seems a bit odd. Anyone else seen much change in valve clearance ?
/ 155D 300hr service. #2
Wow, you have a 155 with only 300 hours? That does seem a bit excessive for 300 hours but not sure about 38+ years. :D
I know right. It's a real nice tractor. Almost too nice. Lol. .004 isn't bad given the fact this thing turns 2700 and the rocker arms aren't very big. And having decompression isn't doing valve spring pressure much favors over the years. But was just wondering what anyone else has seen in theirs
/ 155D 300hr service. #4
I was thinking the same thing????:confused2: A 30+ year old tractor with only 300 hours?
Not the best pics but the nephews loved driving it. Mind you it was in low range first gear at 1500 rpm lol
/ 155D 300hr service. #8
Looks to have been kept in the shed since 1980. Assuming that is the original paint. :thumbsup:
I put 827 hours on my 2002D in the six years I had it. I have put 561 hours on my Bobcat in the 2-1/2 years I've had it. No doubt we all use our tractors differently.
/ 155D 300hr service. #11
And a matching shirt.
:laughing: pants even match the seat. Wasn't for his hair you wouldn't know he was there. Just having a little fun with the OP.
Still was very well kept. Doesn't look as though it was repainted either.
Original paint. Tires and all original implements that it came with it the day it was new. I'm the second owner. I've put almost 100 hours on it since I've had 6 months.
2017 TOYOTA CAMRY SEDAN (A59912)
2017 TOYOTA CAMRY...
ROANOKE LONG ARM DITCH BANK MOWER (A63291)
ROANOKE LONG ARM...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
Caterpillar 16G Motor Grader Service Manual (A63117)
Caterpillar 16G...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
