If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #481
I don't know, but guess it is the same as our 2017. No DEF and no regen.
The Doosan is quieter than the Kubota that was in the 2013 F Series
   / If you have Toolcat questions, ask them here... #482
Do you notice that the traction control is that much better on your 2017?
DEWFPO
   / If you have Toolcat questions, ask them here... #483
Yep, it makes a big difference. Terraces and ridges where the 2013 F series with no traction control, would stop moving and spin two diagonally opposite wheels, the 2017 G series with traction control keeps on going.
This is the view of the 7' brush hog from the seat.
   / If you have Toolcat questions, ask them here... #484
I️ own a 2012 toolcat F series and would like all front end controls on the joystick similar to new models. Is anyone aware of an upgrade kit or process?
   / If you have Toolcat questions, ask them here... #485
The process that I used is called "trade in". :D
I don't have a picture of the F series joystick, what is different?
Here is the G:
   / If you have Toolcat questions, ask them here... #486
crap they still haven't moved the windshield wiper switch in the G.. I have the F series and blowing snow last night god what an akward place to put something.. and I don't like them on unless I need them as the screeching drives me nuts.. have to look down at your side.. not an instinctive reach at least not yet..
   / If you have Toolcat questions, ask them here... #487
Yep, I have bumped that switch on several times. :thumbdown:
Guess I should make a hinged cover for it. :thumbsup:
   / If you have Toolcat questions, ask them here... #488
i have a 5610 g series its like grabbing a beer can its so big
   / If you have Toolcat questions, ask them here... #489
The F only has the center left/right toggle. The 5 perimeter items shown around the toggle are missing, located as individual switches by the armrest. Bad design, I'll look into the upgrade cost/experience and let you know (versus and upgrade.....just saying!).
   / If you have Toolcat questions, ask them here... #490
Hi I was wondering if you guys would be able to help figure out if my toolcat has hi flow or not. I have a 2010 toolcat 5600 d series. Doesnt say hi flow on the ram up front buy i believe the previous owner re painted it at one point. How am i able to determine if its hi flow or not.
   / If you have Toolcat questions, ask them here... #491
on the bobcat 590 the auxiliary hydraulic switch is press once for standard and twice for high flow
   / If you have Toolcat questions, ask them here... #492
Thanks ill give that a shot and see what happens.
   / If you have Toolcat questions, ask them here... #493
Mine has a switch on the console near the armredt that lights up when you switch to high flow. 2011 f series. Just a Google switch
   / If you have Toolcat questions, ask them here... #494
looking at a 2004 with just under 700 hours. are there any special procedures that i need to know to test the drive motors or anything else before i go look at this machine?
   / If you have Toolcat questions, ask them here... #495
Good Afternoon, I am new to the forum. I will ask my question and give what information I think may helpful in diagnosing my problem. I have a 2008 Toolcat which I pruchased used last fall. I have never owned a Toolcat before but I had it throughly inspected before I purchased it. My main reason for buying the Toolcat was to use it clearing snow from our 1 mile driveway. At the beginning of last fall all function were operational. During the winter I believe that I lots use of the high flow hydraulics. When I try to switch to high flow the indicator light does not illuminate, I do not feel any change in rpm's or see that the toolcat throws further than in standard flow. I am not a mechanic, I do not know much about hydraulics but I have tried to diagnose my issues which I see as: Is the high flow actually working and I am unaware of it. Why does the high flow indicator light not illuminate when I try to engage the high flow option when using my snowblower. How can I best determine if I have an electrical issue or a mechanical issue? Actions I have taken: I have checked all the fuses in the two cab fuse boxes. I have removed the cowling so that I can get at the electrical connections inside the cab and have tested those using a test light and they seem to work properly (except for the switch light not illuminating.) Prior to this I purchased a new High flow switch and installed that and it did not make any difference (no light, no change in flow.) I still have the cowling removed but would like to put it back together in the next couple of days unless someone has a suggestion. Feel free to ask me any questions and thank you for the help. Steve
   / If you have Toolcat questions, ask them here... #496
   / If you have Toolcat questions, ask them here... #497
If you are going to troubleshoot it yourself, you need a good multimeter and the service manual.
My guess is that there is a electric solenoid operated valve that activates high flow. Make sure the wires didn't get pulled off of it.
   / If you have Toolcat questions, ask them here... #498
If your snow thrower is a Bobcat is it a high flow attachment?? Controller will not allow you to turn on high flow if it is not. Disconnect ACD cable and see if light comes on when activated.
   / If you have Toolcat questions, ask them here... #500
as mentioned if its a bobcat blower and set up for high flow when you plug in the 7pin connector it automatically lights up.. so understanding the blower you are using is a big component of troubleshooting if there is even an issue..
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
