Electric Polaris Ranger
   / Electric Polaris Ranger
For reference powering the charge status indicator, read this and post #130: http://www.tractorbynet.com/forums/...c-polaris-ranger-post4886706.html#post4886706
The easiest thing would be to run a wire from the power supply to one of the fused +12v Bat wires under the seat, because they have a diode that would prevent the back feed from the converter.
Could not find either diode, so I did it the "easy way". Used some small tubing to protect the wire coming from under the hood to under the seat:
Poked the wire into the tubing and pushed it through:
Spliced to the pink 12v bat wire that was on the first deep cycle battery in the series string:
Slid the covering back over to the fuse holder and put it back up out of the way:
The Voltronics power supply is only on when charging the battery packs:
It now puts it's DC voltage through a diode to the constant power wiring system causing the Charge Status Indicator to operate:
It has been about 20 days since I charged the Voltronics Lithium-ion batteries, the SOC was showing 40%:
And 189.3 hours:
Screen shots from before plugging in the charger, Pack voltage is 52.4 volts:
Right click this one and open in new tab, to see it better
Plugged in the charger at 10:30, the Charge Status Indicator started flashing, my wiring modification is working!
Came back after lunch, SOC is up to 64.5%, 17.2 amps going into the batteries. Pack voltage is 54 volts:
Just over 8 hours charge time, the Charge Status Indicator is on solid:
Pack voltage is 58.7 volts:
Fourth time charging was successful.
   / Electric Polaris Ranger #133
Yikes! 58.7v? Any chance that the Sevcon and the motor will disagree with that high a voltage?
No the motor runs on three phase AC, produced by the Sevcon.
Voltronics modifies the DeltaQ charger and the Sevcon motor controller, so there shouldn't be a problem.
Re: Electric Polaris Ranger, Charging the Lithium-ions again.
It has been over three weeks since I charged the Voltronics Lithium-ion batteries, the relocated SOC meter was showing 2 bars:
And 190.6 on the hour meter, nice to have it back in the dash:
Screen shots with just the BMS powered, before plugging in the charger, Pack voltage is 52.5 volts SOC is 17.5%%:
Right click the above picture and open in new tab, to see it better.
Plugged in the charger at 11:20 am, the Charge Status Indicator started flashing, my wiring modification to power it is still working!
The Delta-Q charger is flowing 17.2 amps:
Went out at 5:30 pm, ten bars on the SOC meter and the Charge Status Indicator is on solid:
And the green light on the charger is on solid:
Pack voltage is 58.7 volts and no charge current flowing:
More information overload from the BMS program: :D
Fifth time charging was successful. :thumbsup:
I decided that I want the LOC back in the dash so the hour meter is visible. ---------------------
Put the LOC meter back in the original location, will probably disconnect the red LED battery LOC, since it is not accurate with the new Li-ion batteries:
Checked the wiring diagram:
Unplugged it and pushed out the three connectors for the Level Of Charge meter:
Put rubber tubing over the connectors and taped with electrical tape and plugged it back together:
The key is on and the red LOC LED is off, yea!:
Now it is just a Hour Meter, yea!:
It has been two weeks since I charged the Voltronics Lithium-ion batteries, the relocated SOC meter was showing 2 bars again, just like last time:
And 191.4 on the hour meter
So yesterday after the modification to the LOC meter I unplugged the charger from the Y connection and plugged it in to turn on the BMS. Got a picture of the status before charging:
Plugged the charger into the Y connection at 3:05 pm. Went out at 9 pm, the Charge Status Indicator was flashing slow, meaning over 80% complete. While I was looking at the BMS data, the CSI went solid green, meaning charge complete:
Sixth time charging was successful. :thumbsup:
It was two and a half weeks ago that I charged the Voltronics Lithium-ion batteries, the SOC meter is showing 2 bars again, just like the last two times:
And 192.8 on the hour meter equals 1.4 hours of actual run time, mainly going to the mail box and back:
So yesterday I unplugged the charger from the Y connection and plugged in the cord to turn on the BMS. Got a picture of the Live Params before charging, showing pack voltage at 52.5 volts equals 15% SOC:
This shows the voltage of the 16 cells in the pack:
Plugged the charger into the Y connection at 11:20 am, to start charging. Checked the BMS at 1:17 pm, the SOC is up to 34.5%, charge current is 17.4 amps:
Went out to the garage at 7:20 pm,
ten bars on the SOC meter and the Charge Status Indicator is on solid, meaning charge complete:
Pack voltage is 58.8 volts and no charge current flowing:
Seventh time charging was successful. [/COLOR][/COLOR]:thumbsup:
   / Electric Polaris Ranger #139
Very cool. I'm about to take the plunge on one of these RangerEVs. Hopefully before spring.
Are you going to post results for each of the 3000 charge cycles those batteries are supposed to be good for? ;)
Prepare to be amazed. :thumbsup:
:D Got to do something to keep the thread active!
As the weather gets colder, I will just plug it in and let it charge without connecting the BMS to the laptop. Sure is nice to have the Charge Status Indicator working now after my wiring modification.
Sterling AT (A55315)
2019 Chevrolet Silverado 2500 4x4 Warner Service Truck (A55852)
2019 Chevrolet...
2022 John Deere 9RX 640 Track Tractor (A53485)
2022 John Deere...
STEAM CLEANER (A55745)
19010 (A55851)
19010 (A55851)
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
