Cab owners - several questions
   / Cab owners - several questions #11
Just want to double check: you said you bought a 862 but the link you put is for an 881, not sure the difference?
Sorry, you are correct. The sockets are the 862 units.
   / Cab owners - several questions #13
The 862 sockets plug directly into the LS cab factory sockets without cutting them.
Thanks very much. Do you have a link for the 862’s?
   / Cab owners - several questions #15
I just fixed the link in my previous post
JL, do the ones you used mate up to the LS Connectors? I had the impression that you cut off both sides of the LS plugs / sockets?
Sounds like Drewmon sourced plugs that will mate to the LS connectors. That’s what I want so I just need a link to the 862.
   / Cab owners - several questions #17
   / Cab owners - several questions #19
The bare wires you see are the new lights I installed. The point to the connectors was so they would plug into the factory wire harness without modification
   / Cab owners - several questions #20
I'd have to read the ad, but I believe it does have 2. To do the front and rear you'd need 4 total.
Ok, when you ordered, did you get 1 or 2? The ad, on eBay, is non-specific in my opinion?
Case-IH 370 Steiger (A57148)
Case-IH 370...
17501-FL (A56857)
17501-FL (A56857)
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2018 Chevy Traverse 3rd Row Seating (A56438)
2018 Chevy...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
