Controlling Hydraulic Motors With a 3rd Function Valve
/ Controlling Hydraulic Motors With a 3rd Function Valve #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Although I have W&R Long 3rd function valves on both my tractors, I'm by no means experienced with their use. I have read that these valves are designed mainly for use with hyd. cylinders, not motors. Holding the valves open for extended periods of time can cause overheating both from oil flow and the electric coils that hold the valve open. The manual warns against this but doesn't give specifics.
I plan to build or buy a few implements that use hyd. motors like a sweeper, post hole digger, brush cutter and a cement mixer. Has anyone here had any experience with extended 3rd function hyd. motor use?
/ Controlling Hydraulic Motors With a 3rd Function Valve #2
If you are actually going to use these prolonged use hydraulic motor implements, do yourself a favor and get a motor spool valve as well as maintained switches. In other words scrap the Long setup and build your own. Get the right controls for the applications. ;)
/ Controlling Hydraulic Motors With a 3rd Function Valve #3
One other issue with "regular" cylinder controls is that when you release the valve whilst controlling a motor, the motor stops dead.
/ Controlling Hydraulic Motors With a 3rd Function Valve #4
...which can lead to pressure spikes and damage to motors, fittings, and hoses.
/ Controlling Hydraulic Motors With a 3rd Function Valve #5
I have run a hyd mixer, a couple of hyd chainsaws, and a hyd PHD in various ways off my tractor.
To run a hyd motor, you will want a motor-spool valve if the rotary tool spins fast and has significant
momentum. That applies to vehicle drive wheels and rotary mowers, but not the items I run. In
this latter case, the tools spin slowly and have very low momentum. I actually WANT them to stop
immediately when I shut them off. Pressure spikes are very low.
In the case of solenoid spool valves, I have not had any that don't have 100% duty cycle, so the coils
do not overheat if left on. You CAN get things too hot if your valves and hoses are not sized for
the flows you will be using. Case-in-point: I run my mixer continuously off my loader, using my
AUX valve. My hoses are long (12') and small (1/4"), and they do get pretty warm. But I run my
tractor at idle speed, so that is OK. Sizing calcs I ran indicated I should use 3/8" hose, but I decided
to run the 1/4" for easier hose handling.
An intermittent-use valve, as you would have with a 4-in-1 setup, can be sized smaller than a
continuous-use valve cuz of the low duty-cycle.
/ Controlling Hydraulic Motors With a 3rd Function Valve #6
Some flow diverters are built for continuos duty so this depends on the valve you have.
Depending on how the valve is sized, hose & fitting sizes, etc. heat can definitely be an issue. Frequently the lines used on FEL's are undersize for continuous flow usage.
The run down feature can be added at the implement Vs having a motor spool.
/ Controlling Hydraulic Motors With a 3rd Function Valve #7
Sure. Here is a crossover RV that I installed inline on the work ports, limited to 2000psi. Not the same
as in a motor spool valve that connects both work ports to tank when off. But the pressure spikes of shutting
a conventional valve off are avoided.
Adding a crossover relief valve, similar to yours, is what I am planning to do. I'm looking at this Prince model:
Prince DRV Relief Valve DRV-4HH - Dalton Hydraulic
The implements I have and plan to build have no momentum issues so the valve should protect the hyd. motor and circuit. For any furure implements that have heavy spinning iron, I'll run a separate set of hoses and use a rear remote.
/ Controlling Hydraulic Motors With a 3rd Function Valve #9
The crossover relief valve works, but if all you want to do is avoid pressure spikes when closing the control valve, install a check valve instead that checks to the pump side. When you close the control valve and the pressure in the exhaust side of the motor reaches the cracking pressure of the check valve (say 5-10 psi) the check valve opens and fluid circulates through the motor until it winds down. THe only disadvantage is that you can't reverse the motor because the check valve bypasses the motor when fluid comes in the "exhaust" port.
/ Controlling Hydraulic Motors With a 3rd Function Valve #10
I have that same valve on my bench. Planning on installing it on the 3rd function on the loader. I thought about putting it on my PHD, but can't really see any downsides putting it on the loader. It will protect any impliments there instead of just the PHD. The only other hydraulic SSQA impliment I have at the moment is my Snow plow, which already has a similar crossover relief. Thought about stealing it, but got a new one instead.
My hoses jump pretty good when is stop my PHD at the moment. Planning on setting the new valve at 2,500psi to coincide with the rest of the relief valve stem in the system. The new one should only kick in when the 3rd function is cutoff from the other relief valve.
/ Controlling Hydraulic Motors With a 3rd Function Valve #11
That Prince valve should work fine, and it has adjustable relief pressure. It serves to limit the pressure to your
hyd motor while driving it and kill pressure spikes when stopping it. It is also a large valve that allows flow-
thru for the work ports at high volume (30GPM).
The reason I went the direction I did with the Hydraforce valve is that it is considerably smaller and does
not have to be mounted anywhere. It also was less than 1/2 the price of the Prince. It has fixed RV
and no flow-thru.
Note that when making custom implements that use hyd motors, the most economical motors
for sale will usually be design-limited to 2000 psi (e.g. Charlynn S). To get motors that can
handle the full pressure of your tractor (usually 2500psi for the latest iron), you will need RV
protection like this. Hyd motors that can handle 2500psi and more will be a lot more expensive.
I ran my hyd PHDs slow, as I said, but I waited a while to get a good large hi-pressure motor at
a decent price (7ci White 255). I loved the instant-stop and reversible features.
/ Controlling Hydraulic Motors With a 3rd Function Valve #12
From Everything Attachments web site regarding the WR Long 3rd function valve.
"Our valve is made for momentary use like open / close or left / right operation. It is not made for rotary implements like augers. The valve has a extremely tight tolerance and if held down to use a rotary attachment it will heat up and swell causing the valve to seize. Thanks!
-Josh Nabb, W R Long, Inc. "
David
David
Thanks for posting this.
My W&R Long manual says pretty much the same thing. It doesn't give use limits though, it simply warns against using it for "Continuous duty". This raises the question of how long is too long. The hyd. motor applications I have in mind, like a winch or mixer, have duty cycle times of less than 5 minutes. Would the valve overheat when using it to control a large hyd. cylinder with a long cycle time? $800 was a lot of money to spend for a valve which is limited to controlling only small cylinders on implements like a grapple, plow or 4 in one bucket.
In any case, I appreciate all the comments. I do plan on running a second set of hoses to bulkhead fittings on the FEL which will connect to a rear remote. Had I known what I do now, I would have saved the $800 and done this in the first place.
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
JOHN DEERE C6R36" CORN HEAD (A64278)
JOHN DEERE C6R36"...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2018 KAWASAKI 4010 SPECIAL EDITION MULE (A65054)
2018 KAWASAKI 4010...
2003 Ford Winstar (A64557)
2003 Ford Winstar...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
