Ford 1210 Hydraulics question
/ Ford 1210 Hydraulics question #1
blackrams
Gold Member
Frankfort, KY
Ford 1210
I have a Ford 1210 4wd hydrostatic tractor that I'm mounting a 702a blade on. Bought the blade used but barely used.
The blade came with both up and down hydraulic cylinders and one for rotating the blade but, did not come with the spool valve.
Now, my problem is, I was not aware that some tractors have open center versus closed center valve systems. I bought a used dual spool valve off of a John Deere tractor. I don't know what specific tractor it came off of. Since I already have both the spool valve and the blade, will I screw up my tractor hydraulics by attempting to install this spool valve if, they are not compatible?
New to this hydraulics thing. Figure I better ask before I bite off more than I can chew.
Edited: Should have asked before I bought the valve but, didn't know any better.
Rams
Bump............
Anyone know? :confused3:
/ Ford 1210 Hydraulics question #3
wrong valve "closed vs open system" will blow out your pump
I was afraid of that................. :duh:
Just so I understand, is the Deere a closed center valve or a open center valve?
Rams
/ Ford 1210 Hydraulics question #5
You can test it by putting compressed air into the pressure port and observing if it flows through to the tank port, with the spool centered. It's best not to blow with your mouth because that puts moisture in the valve.
OK, thanks. :)
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2018 Chevrolet Silverado 2500HD Knapheide Service Truck (A61568)
2018 Chevrolet...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
