Shear Pins
/ Shear Pins #1
Magnum3252
Potsdam, NY
2017 JD 1025R
Should I buy JD Shear Pins for my 54" snowblower or get some at my Local Ace Hardware?
/ Shear Pins #3
If you know the size try ebay
if you are close to the dealer, (or any hardware store) and they have a bulk hardware display, you can get them
for very reasonable cost, they are 1/4 bolts, 1" or 1 1/4" long, and if i'm not mistaken
grade 5 with a nylock nut.
/ Shear Pins #4
If you're ever stuck them you can use s regular bolt with a nut but don't tighten it too much.
Make sure the bolt is slightly of a smaller diameter. It helps..
Now while everyone will say get shear pins etc, a regular bolt doesn't have much strength and will shear pretty easily off.. if not easier than some shear pins.
But like I said, if ever the store is closed and you're midwork.. a regular bolt can save the day.
/ Shear Pins #5
Magnum
Shear pins are there to take the "hit" so something else doesn't break that may be more expensive than shear pins. Your decision as to what to use.
If shearing too many pins, find out what is causing this to happen and remedy that problem.
I like to use lock nuts on the bolts and do not tighten the bolts, but leave them loose.
/ Shear Pins #6
Use the JD shear bolts. The bolt is only $0.46 and the nut is only $0.25. Then you will know you have the correct bolts to shear properly.
As you know, your 54" blower housing already has four spare shear bolts mounted on the left side to the rear of the auger housing.
The JD bolt is rated as grade "A17D" which is equivalent to Grade-5
/ Shear Pins #7
When I had a PTO driven snow blower - I used regular 'ol grade 2, 1/4" x 1 1/2" bolts. They sheared sooner than OEM shear pins - but, what the heck - they were cheep and available at the local ACE hardware. Otherwise, it was a 60 mile round trip to the tractor dealer for OEM shear pins.
/ Shear Pins #8
I have a 54" snowblower. Here is a pic of the original shear pins. As yo u can see it is a grade 5 bolt 1 inch long.
/ Shear Pins #9
I twisted a driveshaft because I didn't know to use the Grade 2 shear bolt. I just threw a Grade 5 in and whack, and ruined the PTO shaft. Could have been more expensive than that. Now I know.
/ Shear Pins #10
That's got to be frustrating! But the OP has a JD 54" snow blower which requires a grade 5, 1/4" bolt for a shear pin.
/ Shear Pins #11
A shear pin is just a bolt and usually a grade 2 with no markings on the head. Some things use a grade 5 and are identified by three marks on the head. Just check the owner's manual and buy bolts at the local farm store in the bulk bin.
/ Shear Pins #13
Well shucks, that's the second time today I forgot to ad my pic.
/ Shear Pins #14
100% agree - I grabbed a handful several years ago and still have 1/2 left - doubt I spent $5 on the whole bag of them from Rural King
/ Shear Pins #15
Magnum
I always snug em up. Not very tight, but I figure the slight elastic stretch relieves the shear zone as it is cut in two.
/ Shear Pins #16
I do the same, and I also add a drop of blue lock-tight. They last for a very long time this way.
/ Shear Pins #17
What I found is that 'hardware store grade' bolts stretch and distort B4 they shear while a grade 5 makes a nice clean break.
The trick is to not have a thread in the shear area as that is a built in fault so to speak.
I don't torque up tight, just snug and always use a nylon lock nut.
The softer bolts once sheared are hard to drive out while a grade 5 will simply pop out easily with the outers usually long gone and it is simply a bit tricky to align the holes to press out the captive shaft remnant (that is on the augers) an my fan I never find either halves, LOL. (I have a gravel drive)
Oh, I located a manual at one time and the factory actually did call for grade 5.
/ Shear Pins #18
Manufacturers have gotten a little more snarky lately and recently I have seen two things with grade 10.9 metric socket head cap screws (bolts) as hear bolts that are hard to find if not bought from a dealer. Most hardware store metric socket head cap screws are grade 12.9 so to be true to the equipment you almost have to buy from the dealer and the price is many times as much as hardware, even though it's the same thing. It's OK but I was able to find some grade 10.9 on EBAY.
I'm not sure but I think 10.9 is similar to grade 2 in that it's not heat treated while grade 12.9 is likely the same as grade 5 with mild heat treating. it's kind of a mystery.
/ Shear Pins #19
Well - I thought ASTM grade10.9 was equal to SAE grade 8. Looked at my torque tables and now I'm not so sure. Have to see if there is a cross-reference table somewhere.
/ Shear Pins #20
"..a regular bolt"?
"Make sure (it's) of a smaller diameter"?
Don't take this the wrong way, but this is some of the worst advice I've ever read on the internet.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2004 Bulter Pole BP-2080-A T/A Pole Trailer (A60352)
2004 Bulter Pole...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2020 KOMATSU D51PXI-24 CRAWLER DOZER (A62129)
2020 KOMATSU...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
832718 (A61166)
832718 (A61166)
