Hydro pedals sticking
/ Hydro pedals sticking #1
Jon E
Member
Southwestern Vermont (on the NYS line)
2014 TYM T353HST
Got a problem with my T353 HST that just showed up yesterday. I had to drive my tractor back and forth between my house and my parents' house, a distance of about 1/2 mile. Did this three times, round trip. I was in high gear and pretty much pedal to the floor. At the beginning of the return trip, I found that the forward pedal was not returning to center like it should, and of course neither was the reverse pedal. I would be moving along at pretty much any speed, from a slow crawl to full-out max speed, at any RPM, and I would take my foot off the pedal and I would keep right on moving. The only way to stop would be to tap the other pedal to force both of them to return to center, and the tractor did not like that very much. I did have to use the tractor a bit more for the day, and I noticed that as the day wore on, the reverse pedal seemed to go back to normal (i.e. return to center immediately) but the forward pedal would still stick. Enough to make working with the machine somewhat dangerous.
I should also add that yesterday was the first time in over a year that I had used the rear PTO. I hooked up my post-hole auger to dig a hole for a new mailbox post. I am wondering if that might have had anything to do with it?
I would like some help on what I should be looking for to fix this issue, and if anyone else has experienced this? My local TYM dealer is gone, packed up shop and either moved or sold out, and the nearest dealer is about 70 miles from me and rather inconveniently located.
/ Hydro pedals sticking #2
Check all the linkages on the hydro pedals under the tractor and lube them. This usually solves the problem.
/ Hydro pedals sticking #3
Agree, just look for the pivot point and give it a good soaking of WD-40, normally have to do this a couple times a year.
/ Hydro pedals sticking #4
The pedals on my 4105 have a couple of grease nipples on the underside 'pivot'. The location/existence of these 'zerks' weren't included in my Owner Manual, probably because they were a modification and the Manual hadn't been updated. (discovered two that had been removed, but undocumented, too)
So they get a shot of grease every now & then.
Bi-annually I'll wander around the tractor with a can of lanolin lubricant and spray anything that moves (linkages/joints) that doesn't have its own dedicated nipple.
/ Hydro pedals sticking #5
I had the same symtoms on my tractor and found the pedal return spring was broken. The spring is behind the linkgage and is hard to see unless you get under the tractor and look up.
/ Hydro pedals sticking #6
just hit the zerks with a lighter weight grease, and spray the linkage with PB. mine did the very same thing! their is a tension certering piston on the outside of the linkage, that helps the pedals back to center....
2020 HAULOTTE 3522A TOWABLE ELECTRIC BOOM LIFT (A65056)
2020 HAULOTTE...
2019 KENWORTH T680 (A67714)
2019 KENWORTH T680...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
2019 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2019 CATERPILLAR...
DYNAPAC CA2500D PADFOOT ROLLER (A67714)
DYNAPAC CA2500D...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
