LM36HST problems
/ LM36HST problems #1
alangdon62
Garner, NC
Cabelas lm36h
This is a list of problems I have not been able to get Cabelas to look at or fix.
Dash lcd part goes dark in about 30 minutes of operation. That's the fuel, hour meter and, the exhaust regen warning.
A growling noise in the left final drive which has gone away.
Loader valve gimbal broke. could not move the loader up. It was stuck going down had to force it to get it to stop which broke the gimbal. It was put together wrong. The only tractor I could get the part for was a Kioti. It was the same casting. And the machining was not finished on it either. Took me about two hours with a dremmel tool to git it to go together. The part TYM wanted me to buy was the assembly at 289.00. Cabbalas will not sell me anything at all for the tractor. The part from Kioti was 56.00.
Steering orbital valve! While working on the loader I kept getting oil on the back of my hand. It turned out the oil was coming from the orbital valve top seal. Manual says if the seal is leaking change out the seal. It has instructions for changing it. There is no part number. TYM wantS to sell me the whole part. 902.00. Cabelas says no warranty.
Cabelas is not honoring the 3 year warranty and now is refusing to sell me parts! Can't even buy filters. Getting ready to hire a Lawyer!
/ LM36HST problems #2
TYM has had issues with the LCD dash, but Cabelas should handle the warranty. The loader on that is a Woods so TYM has nothing to do with it. But TYM should have a seal for your oil leak.
/ LM36HST problems #3
I tried to get him to fix my display. He kept it over a month and said he never saw it go out so I brought it back home. I use it three hours the next day and it started going dark again so I will have to take it back again. That guy sure made me feel like he knew all about these tractors before I bought it, he knows much of nothing. They don't have any way to test the computer without getting the scan tool from another store in a far away state. I told him I was going to remove the DPF. He said i would have to remove the sensors also. I don't know why he would think that, there was no need to.
/ LM36HST problems #4
You can find the filters cheeper on line or get them from Smith's in rebel city. He has them in stock. Ask for Tony.
/ LM36HST problems
hay Bud. Scott is the service righter and Max is the mechanic. Max has been out sick for the last 6 months. He did work a half day of which he worked with mine for and hour. He did not see anything wrong with the dash. As hot as it was he should have been able to see the black growing up from the bottom. And he could not the the final drive to make any noise. I told him I could get it to make the noise when ever I wanted. He did not call me. It seems to have gone away or I'm use to it now.
The orbital valve I should be able to get the seal through a hydraulic repair shop.
Cabelas is not honoring any warranty on my Tractor.
I got Tony in my phone already. The guy in Wilson says if I get him part numbers he will sell me parts for an added fee. Parts will have no warranty because they aren't going on a TYM tractor he says. This guy is a joke.
/ LM36HST problems #6
Yeah I told Scott and Max that there is a known problem with the TYM dash panel going out. They said they never heard of it. I said I contacted tym and was told of the problem so you need to go ahead and change the panel. When they scott called me and said the tractor was ready I thought it was replaced. We I got there to pick it up Max came out and said they didn't replace it because it didn't go out. I am in Harnett Co. so not that long of a haul but I was mad that they didn't even run the tractor an hour. I am going to take it back again in the spring when I'm not using it.
I went an picked up two filters. Scott said they were the right ones. I should have checked the numbers but I took his word for it. Got home and drained all the hydro oil and removed the filters. When I went to install the new filters he had given me the wrong one. I called him and told him and gave him the part # I needed. I told him my wife works in RTP and comes by there on I40 and would stop and pick them up. He said no she could not do that because I bought them using my tax exempt card and I would have to be the one to do it. So I called Tony he had the hydro filter but not the hst one. Found it on ebay. Both were less that Cabelas. The big hydro was $79 and Cabelas and I got it for $38.
Anyway when I took the two filters back to Cabelas I told them I would never spend another dime in that store. Was about to buy a tidewater boat from them, but bought a seahunt from Chatlee because of there worthless service Dept. Billy Smith was mad that I bought the tractor from Cabelas instead of a TYM from. He first said because of that he would not service it or sell me parts. After I told him I had bought other things from in the past, Box blade, trailer, ect. He said he was sorry for saying that and would help me if needed
/ LM36HST problems #7
Anyone saying that the dash isnt a known issue is either lying or doesnt know what they are talking about. I have a 2016 LM36 and had the same fading dash issue, called my Cabelas and they were fully aware of it and said it didnt affect every unit but quite a few. They even had replacement dashs on hand for this, came out the following week, didnt even start the tractor, just replaced it. New dash is much nicer and TYM badged.
I just did my 50hr service, here are the filters I cross referenced to:
Air Filter : Inner : #13151035040 Outer: #13151035020
Fuel Filter : Stock #129A00-55800 WIX: #WF10176 ( I used WIX )
Oil Filter : #12915035153
/ LM36HST problems #8
Any chance you have the other filter numbers? my lm36h has a fuel filter inside a glass/plastic bowl and a hydraulic filter under the trans that I haven't found numbers for yet.
2004 John Deere 544J Articulated Wheel Loader (A64553)
2004 John Deere...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
2019 Chevrolet Express 2500 Cargo Van (A64556)
2019 Chevrolet...
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
