Your towing rigs and trailers
   / Your towing rigs and trailers #2,801
Nice looking setup, I wish you lived closer, I could borrow some of those implents when I need them. I'd even store them for you for free.
Hahaha! Thanks! We built a 40x20 barn last year but already running out of room.
   / Your towing rigs and trailers #2,802
Thanks! Love the expedition and trailer. Have not had much time w/ the Kubota yet.
   / Your towing rigs and trailers #2,803
My set up in various recent states of development. That is a 7700 pound GVWR 20' dual brake Superior made trailer pulled by a 2016 Toyota Sequoia loading a 2017 Kioti 2610 hst with FEL and Bush Hog. Pulls really nice. And a shot of one of my food plots. Also recent.
   / Your towing rigs and trailers #2,804
Lost access to the T250 EcoBoost van when we sold the company. Wife wanted a sailboat, so we bought a 2016 Tahoe LT with the Max Towing Package. Has the 5.3 that pulls a lot better than the 4.8L Express. Rating is 8,300 lbs.
Sailboats have heavy keels and are up in the windstream, so they can be a hassle to tow. This is just under 6,000 lbs. Dragged it back from a Ontario.
We like the gage package with coolant temp, ammeter, and oil pressure. The console display also has transmission temp and actual tire pressure in each tire. And a ull-size spare.
   / Your towing rigs and trailers #2,806
My Best Beverly Hillbillies moment...trip taking the tractor and new implements down to the ranch.
Trailer is a 15k 22’ tilt deck. It was actually very well balanced and it towed well.
   / Your towing rigs and trailers #2,807
I don’t know anything about trailers or towing....but that looks like a lot of Tractor for that trailer?
   / Your towing rigs and trailers #2,808
Not sure if you taped your supervisor to the fel or glued his sandals down to the deck but he is lookin a bit perturbed with you;)
   / Your towing rigs and trailers #2,809
Tractor weight is 4600 pounds. Add that much more for the loader and implements. He said it's a 15k trailer. Sounds fine to me.
   / Your towing rigs and trailers #2,810
Tractor is about 8500 lbs with the hoe on it. It’s plenty of trailer, but that load is close to the max.
The boy was busy playing and I made him stop and look at me.
   / Your towing rigs and trailers #2,811
3Lfarms. I know people hate it when it’s pointed out to you when your load isn’t secured correctly. That kid is going to fall of on the first corner. Set him in the tractor and buckle him up. He will have a blast.
   / Your towing rigs and trailers #2,812
Duct tape works well for small kids. Will secure them to any type of trailer. :laughing:
   / Your towing rigs and trailers #2,817
So today I had my new trailer behind my 17F350 cc. Trailer is a Maxxd 16,500 GVW. I believe cargo is. 12900. Had the Kubota l3700 on it . Back over the trailer tires where it should be and the back of my truck looked like I had 30k in the bed.. sagging like crazy.. pretty surprised.. I think I need to put air bags in it.
   / Your towing rigs and trailers #2,818
Fords have softened up the suspension to increase ride comfort. They will sag a bit. The overloads will pick up pretty quick. Worst case back the tractor up a little if you can to pull some pin weight off. You can also get a weight safe hitch and really dial in the ideal hitch weight
Brett
   / Your towing rigs and trailers #2,819
It's a tight fit with the mower. Have to detach the 3 point and back right up against it.
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2019 KENWORTH T680...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
