Todays shop time.
/ Todays shop time.
I was going to do a firewood door but that's not happened in 6 years. My biscuits jointer was at the house so I didn't do that either. I planned on glueing triangles in the corners of the finished box.
/ Todays shop time. #342
My guess is that the box is about a cubic yard and that a cubic yard of wood could weigh around 1,000 pounds.
I am an over-engineering kinda guy, so I'd be thinking more along the lines of 2x2 (or maybe a bit smaller) lengths glued and/or screwed, inside all the joins.
For the fourth side, to compensate for the effective zero glues strength, I'd be considering gluing and/or screwing a strip of ply that runs perpendicular to the joins. I'd probably be looking at 3 or more inches wide. This would be on the inside and wouldn't be a significant aesthetic problem.
What is the little 'box' on the floor of the box, evident in the first photo?
Ken
/ Todays shop time.
The box is only 23"x23"x23" so maybe 5 cubic feet heaped. The box in the floor is a recessed wheel. IMG_0674.JPG
/ Todays shop time. #344
Cool idea for the wheel.
23" cubed is a tad over 7 cubic feet. Looking a lot more manageable now. Probably still worth reinforcing the fourth wall. I suppose you can always do it later, even if the box is assembled, although clamping will be more difficult. But, if you glue and screw, then there won't be a need for clamps.
/ Todays shop time.
You're right on the volume. It should still be manageable. I got the triangles glued in. IMG_0675.JPG
/ Todays shop time. #346
Those triangles will do the job nicely.
Gotta love the Bessey clamps..
Looking at this latest photo, is looks like you have the grain of the three pieces of ply running in the same direction. In the first photos, they looked like the centre panel had its grain running at 90 degrees to the other two panels. If all three are in the same direction then ignore all the fuss I was making about zero glue strength. If not.. :)
/ Todays shop time.
It is that way but since it's plywood I'm not sure how much difference it makes.IMG_0678.JPG
/ Todays shop time. #348
I installed Fujitsu Halcyon 36000 BTU heat pump in my shop. It isn't the most efficient machine but since it will be operated almost exclusively during the day when power is generated by our PV it was the most cost effective solution. I did the installation by myself and paid only for evacuating and charging the pipes.
/ Todays shop time. #349
Let me try explain my thinking (which might be totally wrong).
We need to accept that end grain gluing has, to all intents and purposes, no strength.
Imagine, for the sake of the discussion, that you make up your own ply, consisting of two boards. The bottom board is Ash and the grain runs east-west. On top of that, you glue a board of Oak with its grain running north-south.
Rip the ply in half, along the grain of the Oak.
If you were to glue those two halves back together again without changing any orientation, the Oak will be glued long-grain to long-grain (lots of strength), and the Ash end-grain to end-grain (no strength). The joint has 50% glue strength.
If you were to glue those two halves back together again but this time rotating one board 90 degrees, the Oak will be glued long-grain to end-grain (no strength), and the Ash end-grain to long-grain (no strength). The joint has zero glue strength.
Ken
/ Todays shop time. #350
I ran out of plywood for the 4th side. I glued up scraps of plywood for that side. I've never done that before so we'll see how it turns out
I think we have to remember this from the beginning, not a perfect world, nor is my woodshop for sure. You use what you've got...
Assuming 4570 doesn't chuck logs into this thing from twenty feet out, this wood holder looks like it will do great. I work in wood and reinforce the same way. I have never had a glue joint rip out; have had the wood fail, but not the glue. Today's glues are insanely strong. Titebond 2 or 3 are my choices.
Franklin International 1414 Titebond-3 Ultimate Wood Glue, 16-Ounce - - Amazon.com
Have learned something good about grain and glue here, but admit I tend to just build it up to strength needed, like 4570 is doing. I built a carryall box a few weeks ago, used lots of glue and screws were mostly for holding it together while the glue finished setting up. And I throw things in there, not like 4570 will. That glue is just not going to give up.
/ Todays shop time. #351
It would be a simple and interesting experiment to conduct.
Cut a sheet of ply (an off-cut will suffice) into 3 pieces. Use Titebond-3 glue to glue two of the pieces together with the grain of the outer layers parallel and the third piece with the grain at right angles. The two joints will have been made using the same wood, same glue and same clamping pressure. Once the glue has set, try to break the joints. It would be nice to be able to devise some way of quantifying the force needed to break the adhesion.
My guess is that the perpendicular pieces will give way a long time before the parallel ones.
I have neither plywood nor Titebond, otherwise I'd do the experiment myself.
Ken
/ Todays shop time. #352
daugen,
I did a quick Google search and found this.
Plywood Edge Glue Expt - YouTube
What he says at 3:15 seems to confirm what I am suggesting.
I agree with you that the box will be fine. The triangular bracing 4570man glued into each joint is going to significantly increase the strength of the box. They provide lots of long-grain adhesion which, with modern glues will be incredibly strong, as you say.
Ken
/ Todays shop time. #353
Having built many small birdhouses and feeders from scratch, I am reminded of
a very well known quote of Aristotle:
The Whole is Greater than the Sum of its Parts.
Strength comes when it's all together, not from just one seam to the next.
I think I remember telling my wife once will you wait until I'm done....
Somewhere in my barn I have a home made weight box I built for my Gravely garden tractor years ago.
Heavy oak construction. Lots of glue and bracing and I really wondered if the bottom would fall out when I loaded
400 pounds of weights in there. Nope, though when it did fail from not being secure enough used on the front of a tractor out in the field,
it failed not at a wood joint but at the stress line. Wood snapped on the hanger part. When I rebuilt it, it was modified with steel plating
over the hangar. That's when I learned just how strong that glue was. Not from the birds in the birdhouses...:rolleyes:
/ Todays shop time. #354
True. However, Thomas Reid, in his Essays on the Intellectual Powers of Man, 1786, tells us that A chain is as strong as its weakest link :)
I guess, on the intellectual scale, Aristotle probably trumps (seems weird using that word too denote something good :D ) Reid, although Reid makes a pretty strong argument :thumbsup:
I agree with you about the strength of modern adhesives. I have done the test. I glued two boards (solid wood, not ply) together and then broke them apart. They separated by cohesive failure of the wood rather than adhesive failure.
/ Todays shop time.
I glued it up that way because it was the only way the pieces would fit together and form a large enough panel. Really it would have worked with only 2 sides, but I wanted 4 to contain the dirt. One thing I did learn is plywood joints hold a lot more glue than a solid wood joint. I used titebond 3 for this project because again it was all I had. I prefer 1 or 2 because they'll wash out of your clothes.
/ Todays shop time. #356
sounds like we've got that quite covered.
And I just learned something new, having Titebond 1, 2 and 3 lined up in my shop.
Didn't realize the first two were more "washable". Not that I should be using any of this stuff with nice clothes
on. Titebond 3 must have some extra ingredient like epoxy in it.
Plain Elmers yellow glue for inside stuff, nicely washable.
Wish they would develop a better glue dispenser, one that sucked the air out or whatever would prevent glue hardening.
By the third or fourth time I'm in that bottle, it's beginning to get unhappy and I'm looking for wire to poke in the clog.
I know you can buy better bottles aftermarket but it would be nice if Titebond would provide something better than a ketchup bottle.
/ Todays shop time.
The clear tip pulls off the lid for cleaning. I think it's pretty trouble free and works pretty good. I had some gorilla wood glue. The glue worked fine and wasn't like that other foaming crap they made. The bottles are awful though. They're too stiff to squeeze once they get more than 1/2 empty.
/ Todays shop time. #358
I gave up on bottles for that reason. I take the cap off and pour some out now.
/ Todays shop time. #359
That makes sense, given that approximately half the surface is end-grain, which sucks up the glue. One would want to be very liberal with the glue to try to prevent glue starvation in the joint.
I think we have pretty well exhausted the plywood gluing question, but I have another question for you - how are you planning to use the box? From the size of the wheels I would assume that it's not going to be wheeled on turf or gravel. Are you going to wheel it to and from the woodshed/pile on a paved path? ; Do the outdoor carrying with pallet forks? ; Other?
/ Todays shop time.
My wood shed is 2 miles from the house. I load wood on my truck and haul it to the house and stack it in the garage. From the garage to the stove is about a 30 yard trip across tile and hardwood. That 30 yard trip is all the cart will be used for. And the wood sheds a lot of dirt in the house. I hope to contain most of that. I know it's not the most efficient setup ever, but it's about the best of my options.
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
213101 (A64276)
213101 (A64276)
2009 Dodge Charger Sedan (A64194)
2009 Dodge Charger...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2018 Ram 2500 4x4 Crew Cab Pickup Truck (A64556)
2018 Ram 2500 4x4...
