Dirt Moving Mahindra customer satisfaction
/ Mahindra customer satisfaction #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
I’m new to Mahindra so don’t know much about them. Mostly Fords and Massey Ferguson‘s in my past. What is the overall experience from Mahindra customers? Currently I’m looking at Kabota Mahindra in new Holland. I know Mahindra tractors are fairly heavy and built a sturdy but how was it overall reliability and dealer network? Thank you
/ Mahindra customer satisfaction #2
It all depends upon the particular models, and dealers. Some models have more issues than others. Some dealers aren't top notch, some are. The same goes for all brands of tractors.
Keep doing your research on both of the above.
/ Mahindra customer satisfaction #3
I’ll second that. Mahindra makes some of the larger models and gets chassis for some of the smaller ones. The chassis they get are from TYM and Mitsubishi. What size are you looking at?
/ Mahindra customer satisfaction #4
I have only had my 2565 for a few months and only have 30 to 35 hours on it but so far I haven't had any problems. My only contact with the dealer has been to ask a few questions which he has answered fine.
One thing I will mention, whoever translated the manual, english wasn't their first language.
I have no regrets and am impressed with the tractor.
/ Mahindra customer satisfaction #5
I have a 4540 that I bought last February. I am not overly impressed with the fit and finish. Some of the parts look like they were cut out with an ax. The forethought that went into placement of components, like filters, seems to be lacking also. When they talk about built in weight they ar not kidding. Everything on it is built to add weight. As an example, the almost non existent tool box is held on with two 3/4 inch (I think, havent measured them) bolts. 1/4-20 would have done the job. Many of the fasteners are VERY, MUCH TOO TIGHT. I decided it would be a good idea to retorque the lug nuts and add some anti-sieze. I had a 3/4 inch breaker bar with a 3 foot piece of pipe and my feet still came off the floor taking them loose.
The owners manual is virtually useless. Not only is there a problem in translating to English but there is very little useful information as well.
Mine is also throwing a OBD code that means something is wrong with the fuel rail. It is a proprietary code that only Mahindra dealers can read and reset so I have to take it back to the dealer (80 mile round trip).
All in all if I had to do it over again, I wouldn稚.
/ Mahindra customer satisfaction #6
I知 new to Mahindra so don稚 know much about them. Mostly Fords and Massey Ferguson壮 in my past. What is the overall experience from Mahindra customers? Currently I知 looking at Kabota Mahindra in new Holland. I know Mahindra tractors are fairly heavy and built a sturdy but how was it overall reliability and dealer network? Thank you
We bought our 4540 last August, so far the only things we've had for problems (nothing huge) a code update and we just had a inline restrictor put in which raised the temp some.
About the only thing I've had a problem getting was extra zerts for the backhoe, our dealer finally did get some but Mahindra can make it hard on the dealer to get certain parts. So far we're very happy with the 4540.
/ Mahindra customer satisfaction #7
I have a 2555 hst, very pleased with it, very pleased with the dealer and no issues with mahindra in general. I even talked to the regional distributor and they were helpful. During my research i did look at 4 different Mahindra dealerships..I like two of them but the third one I was not impressed with at all and would not buy anything from them, the fourth not good/not bad just not impressed. oh yeah, i have about 90 hours on it since May, just to give it some context.
Thanks guys for the info. Sounds like they’re not perfect but still pretty decent overall. I think tomorrow I’ll have a closer look but also try out a NH model while at dealer. We need something in the 55-65hp class with loader
/ Mahindra customer satisfaction #10
I believe LS Tractor is making the NH in that size. My local Kubota dealer also sold NH. The NH had the LS metal tag still on the chassis in the rear. Not saying good or bad- just pointing out a lot of companies are just rebranding.
/ Mahindra customer satisfaction #11
for me, once i narrowed the search down to the hp and options i wanted then i think the most important thing is the dealer. knowledgeable, do the sales people have tractors of their own? walk thru the shop and see how organized they are, in my book the shop should be organized but not so clean that it looks not used or they only do lubricant changes. I dont like places where they have pushy sales people following me around everywhere. I like to be able to try the tractors i am interested in, including using the loader to lift dirt, if backhoe peaks your interest try digging with it, etc. The dealership i went to and eventually purchased from let me play all day if i wanted and try differ machines, transmissions, digging , etc. good luck with whatever you purchase.
/ Mahindra customer satisfaction #12
Thanks guys for the info. Sounds like theyæ±*e not perfect but still pretty decent overall. I think tomorrow I値l have a closer look but also try out a NH model while at dealer. We need something in the 55-65hp class with loader
What are you planning to do with the machine? Do you need more weight vs higher horsepower?
I picked a 3550 because there wasn't really a whole lot else that compared for overall weight, front tire size, and hydro transmission. My machine is 6200 pounds (scale weight) with no bucket or rear implement, and tires are air filled. I often run a 2000 lb counterweight - so machine is around 9000 pounds with bucket and weight. For loader work, that's great, for PTO work and climbing hills in high range, that's not so great. It's probably bit underpowered, but that is ok for how I use it. Much larger than the 3550 and you cannot get hydro transmission - which is very important to me.
As far as the company goes, my experience has been mixed. My machine had early problems that took, in my opinion, too long to solve. You can find those issues here on the forum. Eventually they did get things straightened out and the machine has been great since then. That being said, I am quite mechanically inclined, and things like a leaking fitting aren't even worth mentioning IMO if they can be fixed with a wrench in 30 seconds. I've also modified a couple things to improve a poor design - like the tilt cylinder that always bends for the steering wheel. Perfect fit and finish is more important to some people than it is to me.
The dealer makes a huge difference (as they do with any brand), since they are your avenue to Mahindra. Depending on your reliance on the machine, it might be worth discussing availability of loaners, willingness to perform warranty repairs on your property, etc. Mahindra isn't typically wonderful with prompt communication - so a good dealer will work wonders in the event of an issue. Plus it is up to the dealer to provide transport, send a mechanic, or provide you with a loaner. Mahindra does not cover any of those items under warranty. Not a huge deal to some people, but for others it makes a huge difference.
Well I went by a dealer yesterday that had two different lines of tractors. One being A premium brand and the other Mahindra. Sat down with the sales and service manager and was told the other is a better product overall from quality of materials, options, and overall reliability. They didn’t say Mahindra was bad or overly negative just that it wasn’t the same quality of product. This is a big dealer with quite a bit of inventory of both brands. That being said the premium line is priced higher so just depends on what you can afford I guess. I was appreciative of the openness and honesty of the dealer. I do have a friend that just purchased a 40hp Mahindra and really likes it so far.
/ Mahindra customer satisfaction #14
It’s going to be difficult to get much help and or opinion from others when we don’t know what you are comparing. Salesman are just that- shocking to see him pushing the higher priced option.
Looking at 55-65hp MWFD with loader tractors. Manual shuttle for ground engagement work. Again they were not biased either way but did say the premium line was worth the extra money. He also told me the Ford 5610 was a very heavy built tractor with a larger motor displacement than newer tractors offered now. He seemed to be almost talking me out of a new tractor which surprised me.
/ Mahindra customer satisfaction #16
What was their other line? I tend to agree with the guy if he was comparing to Deere or Kubota. In terms of stuff like paint, seats, knobs, controls, plastic trim, etc -- the stuff that kind of finishes off the tractor, those two brands definitely are a step above Mahindra. But then again, these are tractors and it's hard to really be discerning about "fluff". The other area I have seen a difference is in the hydraulics, where Deere and Kubota seem to have better valves on their loaders and backhoes, as well as some special functions built into the hydraulics like fast dump, regen, etc, which combine to make the equipment a little nicer and easier to operate. It's something you might not notice or care about, so hard to say if the added cost is justified. To me, you really have to sit on each tractor and operate them to decide what's important to you. Sometimes the first impression will really help you decide. I know the first time I operated a Mahindra after just having been on my previous Kubota, the things that immediately jumped out at me were the horrible seat on the Mahindra (seat itself was cheesy and suspension was nil) and the abrupt touchy loader control which lacked the finesse I'd become accustomed to on Kubota and Deere machines.
/ Mahindra customer satisfaction #17
After following the thread that Luke put in post 8, I would never even consider a Mahindra.
Not because of the machine issues but because of the lack of customer service.
Which is the title of this thread.
/ Mahindra customer satisfaction #18
one other thing to mention, and opinions are all over the place on this, but you may still want to consider it, think about if DPF/DEF/ or not having to deal either of them is a factor for you in making your decision.
/ Mahindra customer satisfaction #19
When I was considering buying the Max 26XL the first question I asked the dealer was whether or not the tractor had a DPF. I told him if this tractor had one I would no longer be interested in buying it. I have a lot of first hand experience running equipment with DPFs and that experience has not necessarily been terribly positive. The filter equipped machinery has not proven in our commercial applications to be reliable on a consistent basis and has proven to be very expensive to have repaired. If 2 tractors are being compared against each other I would pick the one that does not have a DPF system. When they stop working correctly the time lost and money spent to address the situation is a real unpleasant state of affaire.
/ Mahindra customer satisfaction #20
Max26 does not have DPF, but same goes for other tractors with less than 26 HP.
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
Frontier 6' 3Pt Mower (A66408)
Frontier 6' 3Pt...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
Gas Powered Air Compressor (A66408)
Gas Powered Air...
