Just another junk chainsaw
/ Just another junk chainsaw #341
You have good luck finding gems. Wanna sell that one?
116si/120si or 6000i/6800i are hands down my favorite saw for bucking firewood.
And the 115i or ps540 is my go to for limbing.
Hard to beat that combo with anything. And I still have the 7900+BB if I'm feeling frisky:laughing:
Dad scored another 116si a few months back. Older gentleman that dad has known for years. Knew he was a fan of dolmars. Saw needed repair and figured he would have more in it than it's worth so gave it to dad for a parts saw.
Swapped clutch and brake band with another parts saw and a new fuel line is all that was needed.
Had it sold before picking it up. :drink:
Todays pick to go through and flip later.
/ Just another junk chainsaw #344
So this old John Deere cs40 is 15 years old I had to take it apart tonight it wasn't oiling the chain. I just had to basically clean out the oil pump. It doesn't get used much these years but when it was new we cleared 25 acres with three chainsaws this being one of them. It still runs really good it was kind of fun to figure out how the oil pump system works. I'm an old Yamaha mechanic so I've been into plenty of Two Strokes but I've never torn apart a chainsaw to be honest.
They are really simple and ingenious at the same time. This model is really an EFCO 940 I believe. It is kind of hard to find some parts for it. Before taking it apart, I was figuring I would have to make my own new parts (CNC machinist/programmer by trade). But everything is decent and in good nick.
By the way, my chain oiling pump is the non adjustable plastic model with a metal drive gear. If anyone has a cheap metal version that is adjustable, I might be interested for future upgrading.
We also have a CS56 big brother to this one. It has been a great saw too. Never had to do anything except 1 spark plug and clean the air filter.
/ Just another junk chainsaw #345
One thing I noticed (with my manufacturing/QC background), there are a few key items that need to made really well for a saw to last. Yes, the major things like piston/wall and crank /rod clearances, good needle bearings, and cylinder shape/hone marks etc. A 2 ring piston, a good clutch, ignition, and most of all, the ability to get replacement parts. So, I will not be arguing with anybody over which brand is best. Surely there are some duds and loser models, but if you can buy a name brand chainsaw made in the last 20 or 30 years, and can get replacement parts, provided it wasn't ran with out 2 stroke oil, it should be a decent saw.
Lot of pro saws 1 ring. I prefer 1 ring myself. :thumbsup:
27 years on the original piston and 1 ring. ;)
Dad has a saw from 89 that still has not needed a rering from his farm land uses.
I'm reringing this one as it is torn down. So mise well.
/ Just another junk chainsaw #347
Tho it seems logical that 2-ring pistons would be found in all pro saws, that is not the case, as XYZ says. My 79cc Makita (Dolmar)
had only one ring, and my Suzuki RM125 motocross engine has only one ring. My biggest chainsaw, a Husky 2100 has a 2-ring
piston, but they are only 0.85mm thick, the thinnest rings I have run into in any small engine. There IS a version of the 2100 that
comes with thicker rings, and saw racers love this saw.
As for crank bearings, I suspect that ball bearings give better service than needle bearings, but both types are
readily available aftermarket, where I get them.
The later your engine, the more difficult it will be to tune the carb. The H and L adjusters on newer saws will
have plastic caps and other means of making it difficult to tune them. Brand new carbs may have no access
to these settings at all.
/ Just another junk chainsaw #349
I bought a set similar to this for the small carb adjustments. I rarely have to adjust anything,
but when I do, they are handy vs cobbling up a tool at home.
If you pull the plastic caps off, you can use one of those tools, yes. I just cut a slot in the end of the screw where you
use the special tool so I can use a slotted screwdriver.
The bigger problem is that removing the H and L screws, as when you clean out the carb, has been
made very difficult. Often cutting off part of the carb or heating and removing epoxy is necessary.
Some carbs have fixed jetting instead of the H screw.
A brand new Husky backpack blower my neighbor just bought has fixed jetting for BOTH H and L.
/ Just another junk chainsaw #350
A 2 ring is not required, and 2 rings will usually improve reliability but will give up a bit of power.
Are the Shindaiwa's 2 ring? Does Shindaiwa make their own saw or is it a rebadged Echo?
/ Just another junk chainsaw #351
Echo bought out Shindaiwa maybe 20y ago, and stopped making chainsaws with that name on it.
Last year, they brought back the Shindaiwa name on chainsaws, but it is a rebadged Echo now.
I have 2 original Shindaiwa saws (my favorite brand), a 377 and a 500. Both have 2 piston rings.
Shin still makes saws and has shin branded saws. Shin makes saws with echo names on them now too. They merged companies.
The relationship between Kioritz Corporation and Shindaiwa Corporation, both of Japan, started in May 2007, with the announcement of a strategic alliance to explore product and operational synergies. The two companies then merged under one holding company in Japan on December 1, 2008, about the same time worldwide economic conditions began to deteriorate. This ultimately led to the merger of the two operating companies in the U.S. and Japan to reduce costs and grow the combined business.
Almost three and one-half years after the merger of the Kioritz/ECHO and Shindaiwa Companies into YAMABIKO Corporation, the company recently celebrated landmark engine production at its two primary Japanese factories.
The Morioka facility (formerly Kioritz) produced its 50th million engine, while the Hiroshima facility (formerly Shindaiwa) produced its 10th million, bringing total production to 60 million engines.
/ Just another junk chainsaw #354
I have been a fan of Shindaiwa since I bought my multi tool in 2002. I was just wondering if the quality is still as good as what I've experienced. Funny thing, the price is still about same for the M242 as it was back in 2002. $299 Maybe $50 more IIRC.
Did a tree removal and cut 16 cookies for decorations for a friend to help his friends out. Yesterday he showed up with a 4'x2' hand painted sign for the shop.
Businesses cards I have a orange saw on it, but he new I liked lime green. ;)
Just shows me if you do good deeds for free, sometimes you get the same in return.
attachment.php
/ Just another junk chainsaw #356
Me, too.
I have yet to try out the new Shindaiwa saws. Here is a photo from the Echo exhibit at last FEB's World AG Expo.
The 50cc Shindy looks about the same as the 50cc Echo, and lists for $20 less than a new Husky 450.
if you like the echos built by shin then you know the quality. Most of the new designed looking echos are shin made. ;)
/ Just another junk chainsaw #359
529116d1511192381-just-another-junk-chainsaw-shopsign-jpg
Very nice!
Looks like my deere CS40. :)
Another junk saw on and off the bench ripping again 1990 first year 262 with the big carb 87 and the good cylinder K&S
Agline ADM109 Disc Mower (A64047)
Agline ADM109 Disc...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE SB-12-72W 72" HYD SCREENING BKT (A62131)
UNUSED WOLVERINE...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
Paladin 544K 416 IC 105in. Dual Cylinder Hydraulic Loader Attachment (A61567)
Paladin 544K 416...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
