2440 Coolant heater
/ 2440 Coolant heater #1
loganhorse
Reynolds station ky
John deere 2440
What's the correct one for this tractor?
Finding RE313366 and AT72330. So what's the difference between them??
Thanks.
/ 2440 Coolant heater #2
Thanks.
Re313366 is the element only for replacement. At72330 is the complete kit for first time install.
Here is what I have. I feel like I should hear or be able to feel heat when plugged in and I can.
/ 2440 Coolant heater #4
Yep, that's it. Yes you should be able to feel some heat shortly after plugging in. This was a pretty good element but they do fail, re313366 is what you most likely need (or an equivalent tank heater from parts house).
Wouldn't happen to know what size the line is would you? I'm not around my tractor currently.
/ 2440 Coolant heater #8
hoses are 5/8'' inside diameter 14'' & 16'' long
/ 2440 Coolant heater #10
Looks like what's on my 2030, gets very hot to the touch. 20-30 minutes and it starts the tractor easy.
/ 2440 Coolant heater #11
If "hot", electrical cord, and oily surrounding "per the pic" shown, then I'd consider some serious de-greasing.
My recollection of these heaters in my cars and my old 2-cyl 420 JD was they were not very long lasting or of highest quality materials.
/ 2440 Coolant heater #12
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A60352)
2006 Ford F-750...
2012 Volkwagon Passat Sedan (A61569)
2012 Volkwagon...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61567)
2025 Wolverine...
Honda utv cart (A56859)
Honda utv cart...
LandHonor LHR-DFP10 Diesel Fuel Transfer Pump (A60352)
LandHonor...
