2440 Coolant heater
   / 2440 Coolant heater #1
loganhorse
Reynolds station ky
John deere 2440
What's the correct one for this tractor?
Finding RE313366 and AT72330. So what's the difference between them??
Thanks.
   / 2440 Coolant heater #2
Thanks.
Re313366 is the element only for replacement. At72330 is the complete kit for first time install.
Here is what I have. I feel like I should hear or be able to feel heat when plugged in and I can.
   / 2440 Coolant heater #4
Yep, that's it. Yes you should be able to feel some heat shortly after plugging in. This was a pretty good element but they do fail, re313366 is what you most likely need (or an equivalent tank heater from parts house).
   / 2440 Coolant heater #5
Sure glad to see people using block heaters instead of ether, tiger torches, heat guns or tow starting.
Wouldn't happen to know what size the line is would you? I'm not around my tractor currently.
   / 2440 Coolant heater #8
hoses are 5/8'' inside diameter 14'' & 16'' long
   / 2440 Coolant heater #10
Looks like what's on my 2030, gets very hot to the touch. 20-30 minutes and it starts the tractor easy.
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55315)
Koyker Loader...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
2023 Kubota Z252KH-54 Zero Turn Mower (A55315)
2023 Kubota...
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2015 CATERPILLAR...
2015 International Bucket Truck (A55973)
2015 International...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
