2440 Coolant heater
   / 2440 Coolant heater #1
loganhorse
Reynolds station ky
John deere 2440
What's the correct one for this tractor?
Finding RE313366 and AT72330. So what's the difference between them??
Thanks.
   / 2440 Coolant heater #2
Thanks.
Re313366 is the element only for replacement. At72330 is the complete kit for first time install.
Here is what I have. I feel like I should hear or be able to feel heat when plugged in and I can.
   / 2440 Coolant heater #4
Yep, that's it. Yes you should be able to feel some heat shortly after plugging in. This was a pretty good element but they do fail, re313366 is what you most likely need (or an equivalent tank heater from parts house).
   / 2440 Coolant heater #5
Sure glad to see people using block heaters instead of ether, tiger torches, heat guns or tow starting.
Wouldn't happen to know what size the line is would you? I'm not around my tractor currently.
   / 2440 Coolant heater #8
hoses are 5/8'' inside diameter 14'' & 16'' long
   / 2440 Coolant heater #10
Looks like what's on my 2030, gets very hot to the touch. 20-30 minutes and it starts the tractor easy.
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A57880)
2016 FORD F-550...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
